Introduction
Replace motherboard in an Acer Aspire 5100.
Lift the fan and detach the cable that connects the fan to the motherboard.
When detaching the cable, do not pull on the cable itself. Instead, use a small spudger to detach it at the white section that connects it to the motherboard.
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
Pull the ribbon under the keyboard to detach it from the motherboard.
Remove the keyboard.
Open the lid of the laptop and locate the cover that surrounds the keyboard and track pad.
Use the spudger to pry open the sides of this cover.
Slightly lift up the cover to see the ribbon connection.
Release the catch by sliding the two lugs toward the ribbon, then pull the ribbon to detach it from the motherboard.
Lift up the cover from the laptop.
On the cover that was removed, flip it around and locate where the back of the track pad is.
Remove the three screws located at the corners.
Lift up the bracket that you just unscrewed and remove track pad.
Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
Flip the laptop upside down.
Remove the four screws from the back panel of the laptop.
Lift the panel up and set it aside.
Locate the heat sink, which is the copper "L" shaped component, and unscrew the four screws that connect it to the motherboard.
Find the VGA connector located next to the USB ports.
Push out the back of the casing by the VGA connector to be able to get the motherboard out.
Lift up and remove the motherboard from the laptop casing.
Remove the USB add-on card to use it with the new motherboard.
