Acer Aspire 5100 LCD Monitor Replacement
  1. Acer Aspire 5100 LCD Monitor Replacement, Keyboard: step 1, image 1 of 2 Acer Aspire 5100 LCD Monitor Replacement, Keyboard: step 1, image 2 of 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 LCD Monitor Replacement: step 2, image 1 of 3 Acer Aspire 5100 LCD Monitor Replacement: step 2, image 2 of 3 Acer Aspire 5100 LCD Monitor Replacement: step 2, image 3 of 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 LCD Monitor Replacement: step 3, image 1 of 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  4. Acer Aspire 5100 LCD Monitor Replacement, LCD Monitor: step 4, image 1 of 1
    • Unscrew the 2 screws at each corner located underneath the LCD screen.
  5. Acer Aspire 5100 LCD Monitor Replacement: step 5, image 1 of 2 Acer Aspire 5100 LCD Monitor Replacement: step 5, image 2 of 2
    • Locate the wire connecting the LCD screen to the motherboard.
    • Detach the white rectangle located on the motherboard at the end of the wire.
  6. Acer Aspire 5100 LCD Monitor Replacement: step 6, image 1 of 2 Acer Aspire 5100 LCD Monitor Replacement: step 6, image 2 of 2
    • Place the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift up and remove the panel.
  7. Acer Aspire 5100 LCD Monitor Replacement: step 7, image 1 of 1
    • Locate the black and white wire and detach it.
    • You do not need to remove the cooling fan.
  8. Acer Aspire 5100 LCD Monitor Replacement: step 8, image 1 of 1
    • Lift up the monitor to detach it.
Brad Rollinson
1,113 Reputation
7 Guides authored
Cal Poly, Team 14-39, Forte Fall 2010 Member of Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 15,462
