Introduction
This guide will lead you through the steps of removing the LCD monitor and its enclosure.
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
Pull the ribbon under the keyboard to detach it from the motherboard.
Remove the keyboard.
Locate the wire connecting the LCD screen to the motherboard.
Detach the white rectangle located on the motherboard at the end of the wire.
Place the laptop upside down.
Remove the four screws from the back panel of the laptop.
Lift up and remove the panel.
