Introduction
This guide will show you how to replace your old battery with a new one.
The battery is the main source of power for your computer. Without a battery, the
computer cannot be powered on unless it is plugged into a wall socket.
Replacing the battery is an easy task with little risk of damaging critical components
inside your computer.
Shut down the computer and disconnect all external devices and cables.
Flip the computer over.
Ensure that the battery compartment lock tab is in the unlocked position.
Slide the sliding black tab away from the battery compartment.
The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
