Acer AL1714 Power Button Circuit Board Flat Flex Cables Replacement
  1. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement, Power Button Circuit Board Flat Flex Cables: step 1, image 1 of 2 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement, Power Button Circuit Board Flat Flex Cables: step 1, image 2 of 2
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: step 2, image 1 of 3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: step 2, image 2 of 3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: step 2, image 3 of 3
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once side of bezel facing you is decoupled, take the back cover and pry it loose.
  3. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: step 3, image 1 of 3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: step 3, image 2 of 3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: step 3, image 3 of 3
    • Remove the Power Button Circuit board Flat Flex Cable from the Power Supply board under the metal cage.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: step 4, image 1 of 1
    • Remove the Flat Flex Cables from the Power Button Circuit Board.
Christopher Kelly
590 Reputation
4 Guides authored
USF Tampa, Team 1-3, Brown Fall 2014 Member of USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 832
