Accessing Nokia 3100b DC Input
  1. Accessing Nokia 3100b DC Input, Battery: step 1, image 1 of 1
    • Make sure your phone is turned off.
  2. Accessing Nokia 3100b DC Input: step 2, image 1 of 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Accessing Nokia 3100b DC Input, SIM Card: step 3, image 1 of 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Accessing Nokia 3100b DC Input: step 4, image 1 of 1
    • Retrieve your SIM card.
  5. Accessing Nokia 3100b DC Input, Accessing Nokia 3100b DC Input: step 5, image 1 of 1
    • Separate the front cover from the base.
  6. Accessing Nokia 3100b DC Input: step 6, image 1 of 1
    • Using a T6 Torx screwdriver, remove the screws from the screen assembly.
  7. Accessing Nokia 3100b DC Input: step 7, image 1 of 1
    • Separate the screen assembly from the base.
  8. Accessing Nokia 3100b DC Input: step 8, image 1 of 1
    • Note where the DC input is.
  9. Accessing Nokia 3100b DC Input: step 9, image 1 of 1
    • Use a pair of tweezers to remove the DC input from the base.
  10. Accessing Nokia 3100b DC Input: step 10, image 1 of 1
    • The DC input is now removed. Replace as necessary.
Sterling Fuentes
130 Reputation
8 Guides authored
Cal Poly, Team 29-64, Johann Spring 2010 Member of Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Members
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,049
