Parts
No parts required.
  1. Turn off the computer. Before each operation it is important to start with the removal of the accumulator. Take the slide unlocked into position, remove the battery.
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Using the screwdriver Philips # 1, unscrew the 5 fixing screws of the cover. Using the screwdriver Philips # 1, unscrew the 5 fixing screws of the cover.
    • Using the screwdriver Philips # 1, unscrew the 5 fixing screws of the cover.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  4. Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers. Now lift the cover carefully. Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  5. Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
For reassembly, follow the instructions in reverse order.
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,580 Reputation
150 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 110
