Introduction
This guide will show you step by step, how to clean the gears of a bait caster. This will allow you to cast at the distance you are needing.
Use a small Phillips or flathead screwdriver to remove the screw highlighted in red.
After screw is removed, remove the black cover highlighted in yellow.
Remove 10MM nut, highlighted in orange, on handle with a 10MM nut driver.
Once nut is removed, then simple pull handle off.
Remove the side plate that is highlighted in blue.
Be careful not loose inner yoke springs, as they may fall out.
Using a small Phillips or flathead screwdriver, remove the small screws that are highlighted in red.
Once screws are removed, simply pull off side place in order to access the inner gears.
After small screws are removed, twist each knob until they come off being careful not to loose these pieces.
Once cover is released from reel, apply the Abu Garcia lube to the gears highlighted in orange.
2 other people completed this guide.
