Shop the Holiday Gift Guide
How To Remove the Battery Back Plate
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
101
All Time:
2,843
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will assist you with your JVC GR-D290U camera. In trouble shooting issues with your camera, you may want to start with the battery. This guide will offer you step by step instructions on how to remove the battery back plate so that you may observe the condition of the battery. Some reasons you may need to replace your battery may include reduced performance, product inconsistency with charging or battery dying without warning, physical damage, and age of the battery. If you are able to observe physical damage such as leaks, bulges, or corrosion this would be an immediate signal that you need to replace the battery. In such cases, it's essential to replace the battery promptly to prevent any potential damage to the camera.
There should always be precautions taking while handling batteries. First be sure the camera is off, make sure the battery terminals are clean and free from any rust. Use batteries that are only approved for this camera. Do not expose batteries to any excessive heat or flame.
To change the batteries, you may need a screwdriver, plastic prying tool to remove batteries from its compartment, gloves especially if leaking to protect your hands from any chemicals, isopropyl alcohol and cotton swabs to clean any corrosion that may be found when removing previous batteries.
Tools
    1. How To Remove the Battery Back Plate, JVC GR-D290U: step 1, image 1 of 1
      • Remove the two screws on the underside of the camera eyepiece.
      Ask FixBot
    2. How To Remove the Battery Back Plate: step 2, image 1 of 1
      • Remove the two screws connecting the back plate to the camera base.
      Ask FixBot
    3. How To Remove the Battery Back Plate: step 3, image 1 of 1
      • Remove the back plate.
      Ask FixBot
2 other people completed this guide.
Author
with
justin chen
47 Reputation
3 Guides authored
Cal Poly, Team 18-69, Johann Spring 2010 Member of Cal Poly, Team 18-69, Johann Spring 2010
CPSU-JOHANN-S10S18G69
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 101
All Time: 2,843
