AVM Fritz Fon C5 front cover / keypad Replacement
  1. AVM Fritz Fon C5 front cover / keypad Replacement, Back panel and battery removal: step 1, image 1 of 2 AVM Fritz Fon C5 front cover / keypad Replacement, Back panel and battery removal: step 1, image 2 of 2
    • Loosen the back panel using your fingernail/ guitar pick or a spudger.
    • Slide the pick all around the housing until the back panel comes off.
    • Once it's off simply remove the battery from the housing.
  2. AVM Fritz Fon C5 front cover / keypad Replacement, Loosen Housing: step 2, image 1 of 3 AVM Fritz Fon C5 front cover / keypad Replacement, Loosen Housing: step 2, image 2 of 3 AVM Fritz Fon C5 front cover / keypad Replacement, Loosen Housing: step 2, image 3 of 3
    • Loosen the 8 T5 screws, and set them aside.
    • The upper shell / front of the housing consists of filigree bars around the keypad, so special care is required here. In my case, some of these were already broken.
    • Move the opening pick / spudger around the case, lifting off the tabs (orange) with a flat screwdriver. This is done through the corresponding openings in the middle part of the housing (green).
  3. AVM Fritz Fon C5 front cover / keypad Replacement, PCB removal: step 3, image 1 of 2 AVM Fritz Fon C5 front cover / keypad Replacement, PCB removal: step 3, image 2 of 2
    • The circuit board can then be easily removed together with the keypad.
    • Replace the parts to be repaired and screw them back together.
  4. AVM Fritz Fon C5 front cover / keypad Replacement, Speaker and Display Window: step 4, image 1 of 2 AVM Fritz Fon C5 front cover / keypad Replacement, Speaker and Display Window: step 4, image 2 of 2
    • Loudspeaker (yellow) and screen protector (green) are glued on and can be easily lifted out with a flat screwdriver.
    • A transparent piece of plastic (light blue), which was probably used to align the loudspeaker, was no longer needed, nor was I able to take over the piece of fabric (red) in front of the loudspeaker.
    • The keypad got hooked in a few places, so I had to rework the associated openings with a file.
  5. AVM Fritz Fon C5 front cover / keypad Replacement, Assembly: step 5, image 1 of 1
    • Put everything back together in reverse order - make sure that the buttons do not get stuck.
Reverse the steps to reassemble your device.
5 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Peter Scholl
1,413 Reputation
6 Guides authored
AEG-Make&Repair AG Member of AEG-Make&Repair AG
Local Repair Groups
3 Members
12 Guides authored
12 Comments
Yea please cam you help me
James - Reply
I can’t say without knowing your question/problem.
Peter Scholl -
Ich finde auf eBay aktuelle keine 3D gedruckten C5 Oberschalen. Können Sie mir einen Tipp geben, wo man so etwas erhält?
H. Zapf - Reply
Hallo - da kann ich leider nichts zu sagen, da ich meine Oberschale selbst gedruckt habe. Ich habe auch keine Erfahrung wie es ist, wenn man einen solchen Druck in Auftrag gibt - falls Sie da Erfahrung sammeln, fände ich eine kurze Info auch interessant. Viel Erfolg!
Peter Scholl - Reply
Hallöle, kannst du die 3D zur Verfügung stellen.
Grüße
M O -
Past 24 Hours: 11
Past 7 Days: 68
Past 30 Days: 380
All Time: 18,541
