ATT Trimline 210M Back Cover Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. ATT Trimline 210M Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
      • Be careful with the amount of force you use, or the plastic may crack.
      Ask FixBot
    2. ATT Trimline 210M Back Cover Replacement: step 2, image 1 of 1
      • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
      Ask FixBot
    3. ATT Trimline 210M Back Cover Replacement: step 3, image 1 of 1
      • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
      • The cord connecting the speaker is short, and may detach if not done carefully.
      Ask FixBot
    4. ATT Trimline 210M Back Cover Replacement: step 4, image 1 of 1
      • You will have the motherboard and speaker exposed to you.
      Ask FixBot
Juan Carrillo
406 Reputation
3 Guides authored
USF Tampa, Team 4-2, Lacy Spring 2016 Member of USF Tampa, Team 4-2, Lacy Spring 2016
USFT-LACY-S16S4G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 12
All Time: 179
