ATT Trek HD Screen Digitizer Replacement
    1. ATT Trek HD Screen Digitizer Replacement, Back Cover: step 1, image 1 of 1
      • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
      Ask FixBot
    2. ATT Trek HD Screen Digitizer Replacement: step 2, image 1 of 1
      • Pull the screen away from the back panel.
      Ask FixBot
    1. ATT Trek HD Screen Digitizer Replacement, Battery: step 3, image 1 of 2 ATT Trek HD Screen Digitizer Replacement, Battery: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
      Ask FixBot
    2. ATT Trek HD Screen Digitizer Replacement: step 4, image 1 of 2 ATT Trek HD Screen Digitizer Replacement: step 4, image 2 of 2
      • Use the plastic opening tool to disconnect the black battery connector.
      • Gently lift the battery out of the device.
      Ask FixBot
    1. ATT Trek HD Screen Digitizer Replacement, Motherboard: step 5, image 1 of 2 ATT Trek HD Screen Digitizer Replacement, Motherboard: step 5, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
      Ask FixBot
    2. ATT Trek HD Screen Digitizer Replacement: step 6, image 1 of 2 ATT Trek HD Screen Digitizer Replacement: step 6, image 2 of 2
      • Use the plastic opening tool to disconnect the large gold strip underneath the metal plate from the motherboard.
      Ask FixBot
    3. ATT Trek HD Screen Digitizer Replacement: step 7, image 1 of 1
      • Use the plastic opening tool to disconnect the front and back cameras from motherboard.
      Ask FixBot
    4. ATT Trek HD Screen Digitizer Replacement: step 8, image 1 of 2 ATT Trek HD Screen Digitizer Replacement: step 8, image 2 of 2
      Tool used on this step:
      $3.99
      Buy
      • Use angled tweezers to pry up the black tab.
      • Use the angled tweezers to pull out the gold connector.
      Ask FixBot
    5. ATT Trek HD Screen Digitizer Replacement: step 9, image 1 of 2 ATT Trek HD Screen Digitizer Replacement: step 9, image 2 of 2
      • Use the angled tweezers to disconnect the gold connector.
      Ask FixBot
    6. ATT Trek HD Screen Digitizer Replacement: step 10, image 1 of 1
      • Use the plastic opening tool to disconnect the black connectors on each side of the motherboard.
      Ask FixBot
    7. ATT Trek HD Screen Digitizer Replacement: step 11, image 1 of 2 ATT Trek HD Screen Digitizer Replacement: step 11, image 2 of 2
      • Use the plastic opening tool to lift the motherboard out of place.
      Ask FixBot
    1. ATT Trek HD Screen Digitizer Replacement, Front Camera: step 12, image 1 of 2 ATT Trek HD Screen Digitizer Replacement, Front Camera: step 12, image 2 of 2
      $3.99
      Buy
      Ask FixBot
    1. ATT Trek HD Screen Digitizer Replacement, Screen: step 13, image 1 of 3 ATT Trek HD Screen Digitizer Replacement, Screen: step 13, image 2 of 3 ATT Trek HD Screen Digitizer Replacement, Screen: step 13, image 3 of 3
      • Use the Phillips #00 screwdriver to remove the six 3 mm screws holding the black plastic corner pieces in place.
      • Gently lift the black corner pieces out of the device.
      Ask FixBot
    2. ATT Trek HD Screen Digitizer Replacement: step 14, image 1 of 2 ATT Trek HD Screen Digitizer Replacement: step 14, image 2 of 2
      $3.99
      Buy
      • Use the angled tweezers to remove the black cables on each side of the device from their groove.
      Ask FixBot
    3. ATT Trek HD Screen Digitizer Replacement: step 15, image 1 of 2 ATT Trek HD Screen Digitizer Replacement: step 15, image 2 of 2
      • Use the plastic opening tool to disconnect the black cable connectors from each side of the device.
      Ask FixBot
    4. ATT Trek HD Screen Digitizer Replacement: step 16, image 1 of 2 ATT Trek HD Screen Digitizer Replacement: step 16, image 2 of 2
      • Remove the remaining ten 3 mm Phillips #00 screws.
      Ask FixBot
    5. ATT Trek HD Screen Digitizer Replacement: step 17, image 1 of 2 ATT Trek HD Screen Digitizer Replacement: step 17, image 2 of 2
      • Use the plastic opening tool to disconnect the remaining three gold connectors at the bottom of the device.
      Ask FixBot
    6. ATT Trek HD Screen Digitizer Replacement: step 18, image 1 of 2 ATT Trek HD Screen Digitizer Replacement: step 18, image 2 of 2
      • Use the plastic opening tool to pry up the grey plastic panel.
      Ask FixBot
    7. ATT Trek HD Screen Digitizer Replacement: step 19, image 1 of 2 ATT Trek HD Screen Digitizer Replacement: step 19, image 2 of 2
      • Use the plastic opening tool to pry the screen out of the device.
      Ask FixBot
    1. ATT Trek HD Screen Digitizer Replacement, Screen Digitizer: step 20, image 1 of 3 ATT Trek HD Screen Digitizer Replacement, Screen Digitizer: step 20, image 2 of 3 ATT Trek HD Screen Digitizer Replacement, Screen Digitizer: step 20, image 3 of 3
      • Use the plastic opening tool to pry the charging board away from the digitizer.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 503
