ATT Trek HD Back Cover Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
50
All Time:
668
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will help you remove the back cover of your device in two easy steps. This guide is the first step for removing and replacing any internal part of your device. For this process, you will need only one tool, which is specified in this guide. By following the steps, the back cover removal should only take 1-2 minutes of your time and will cause no damage to your device.
Tools
    1. ATT Trek HD Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
      Ask FixBot
    2. ATT Trek HD Back Cover Replacement: step 2, image 1 of 1
      • Pull the screen away from the back panel.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 50
All Time: 668
