Community-Contributed Guide
Introduction
Go to step 1 ↓This is a brief guide for replacing the Speed PCB Assembly on AT-LPW50 Series turntables.
Replacing the Speed PCB Assembly may resolve issues where the turntable does not respond properly to changes in speed, or where the platter does not stop rotating while the speed selector dial is being adjusted.
The replacement Speed PCB Assembly can be purchased directly from the Audio-Technica Parts Department using the following part number:
Part Number: TWPC18P016B01
To order the part, email parts@tli-atus.com and include the following information:
- First and last name
- Deliverable shipping address
- Phone number
- Part number: TWPC18P016B01
Parts orders through this department are available within the United States and Canada only. If you are located outside of the U.S. or Canada, please contact your local Audio-Technica branch for parts availability and assistance.
Unplug the turntable from power and speakers, then place it on a flat level surface
Using a twist tie, tape, or ziptie, secure the tonearm in place so it won't move after being turned upside-down (do not rely on the tonearm hook alone)
Remove the rubber slipmat, belt and platter from the center spindle
Pull directly upward on the speed selector knob to remove it
To reassemble your device, follow these instructions in reverse order. You will need to re-attach the belt to the underside of the platter, and re-balance the tonearm. Here is a guide to re-balancing the tonearm.
