AT-LPW50 Center Base Assembly Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
4
Past 30 Days:
4
All Time:
4
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This is a brief guide for replacing the Center Base Assembly on AT-LPW50 Series turntables.
Replacing the Center Base Assembly may resolve speed-related issues, including the turntable not responding properly to speed changes or operating at an inconsistent or incorrect speed at 33â…“ RPM, 45 RPM, or both.
The replacement Center Spindle Assembly can be purchased directly from the Audio-Technica Parts Department using the following part number:
Part Number: TWMT350552503
To order the part, email parts@tli-atus.com and include the following information:
  • First and last name
  • Deliverable shipping address
  • Phone number
  • Part number: TWPC18P016B01
Parts orders through this department are available within the United States and Canada only. If you are located outside of the U.S. or Canada, please contact your local Audio-Technica branch for parts availability and assistance.
Tools
    1. AT-LPW50 Center Base Assembly Replacement, Center Base Assembly: step 1, image 1 of 2 AT-LPW50 Center Base Assembly Replacement, Center Base Assembly: step 1, image 2 of 2
      • Unplug the turntable from power and speakers, then place it on a flat level surface
      • The turntable will be flipped upside-down, to reduce the risk of scratches to the acrylic dust cover, place it on a soft surface such as a blanket, towel, or sheet
      • Using a twist tie, tape, or ziptie, secure the tonearm in place so it won't move after being turned upside-down (do not rely on the tonearm hook alone)
      • Remove the rubber slipmat, belt and platter from the center spindle
      Ask FixBot
    2. AT-LPW50 Center Base Assembly Replacement: step 2, image 1 of 3 AT-LPW50 Center Base Assembly Replacement: step 2, image 2 of 3 AT-LPW50 Center Base Assembly Replacement: step 2, image 3 of 3
      • Make sure there is something soft underneath the dust cover like a bedsheet, towel, etc to minimize the risk of scratches to the acryllic
      • Flip the turntable upside-down
      • Remove 6 Phillips head screws to remove the metal PCB cover
      Ask FixBot
    3. AT-LPW50 Center Base Assembly Replacement: step 3, image 1 of 3 AT-LPW50 Center Base Assembly Replacement: step 3, image 2 of 3 AT-LPW50 Center Base Assembly Replacement: step 3, image 3 of 3
      • Remove the screw for the ground wire
      • Remove the 4 screws holding the Center Base Assembly in place
      • Gently unplug the 4-pin connector of the Center Base Assembly
      • Remove the Center Base Assembly
      • This is the end of the guide, to reassemble, follow the steps in reverse
      • When fastening the metal PCB cover, make sure all wires are within their channels or the cover might flatten/damage the cable
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. You will need to re-attach the belt to the underside of the platter, and re-balance the tonearm. Here is a guide to re-balancing the tonearm.
ATUS Service Dept
764 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 4
Past 30 Days: 4
All Time: 4
