Shop the Holiday Gift Guide
AT-LP60X Setup Guide
Views: 1.8K
View statistics:
Past 24 Hours:
13
Past 7 Days:
58
Past 30 Days:
195
All Time:
1,847
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide is used to help setup your AT-LP60X after receiving back from a repair.
    1. AT-LP60X Setup Guide, Place Turntable: step 1, image 1 of 2 AT-LP60X Setup Guide, Place Turntable: step 1, image 2 of 2
      • Place your turntable on a clear, flat surface.
      • Ensure there is no power connected to the turntable at this time.
      Ask FixBot
    2. AT-LP60X Setup Guide, Locate and Install Platter/Belt: step 2, image 1 of 1
      • Obtain the silver metal platter.
      • Verify that the belt is installed around the inner ring of the platter.
      Ask FixBot
    3. AT-LP60X Setup Guide, Install Platter: step 3, image 1 of 2 AT-LP60X Setup Guide, Install Platter: step 3, image 2 of 2
      • Place the platter on the center spindle.
      • Rotate the platter to show the gold pulley of the motor.
      • Stretch the belt from the platter over the gold pulley of the motor.
      Ask FixBot
    4. AT-LP60X Setup Guide, Preform Mechanical Reset: step 4, image 1 of 2 AT-LP60X Setup Guide, Preform Mechanical Reset: step 4, image 2 of 2
      • Place the slipmat on top of the platter and press the STOP button.
      • With your right hand, hold the tone arm in place.
      • [OPTIONAL] use the included hook and twist tie for this step.
      • With your left hand, rotate the platter clockwise about 10 times.
      • You should hear a series of clicks and pops.
      Ask FixBot
    5. AT-LP60X Setup Guide, Reconnect Turntable: step 5, image 1 of 1
      • Reconnect the power supply.
      • Connect the 3.5mm to RCA to your speakers.
      • For powered speakers the output switch should be in "LINE", if connecting to an amp/phono input the output should be in "PHONO"
      • The output switch position does not matter if you are connecting to a Bluetooth speaker.
      Ask FixBot
    6. AT-LP60X Setup Guide, Prepare Tonearm: step 6, image 1 of 3 AT-LP60X Setup Guide, Prepare Tonearm: step 6, image 2 of 3 AT-LP60X Setup Guide, Prepare Tonearm: step 6, image 3 of 3
      • Remove the clear plastic cover from the stylus (if present) by sliding the COVER ONLY directly towards the front of the turntable.
      • Unsecure the twist tie from the built-in hook (if present).
      • Ensure the tone arm lift button is in the outward position.
      • The setup is now complete and you are ready to try a record!
      Ask FixBot
If you have any trouble setting up your turntable and/or a new problem arises, feel free to contact a technician at (330)686-2600 ext.5004 or service@atus.com
Author
with
Anthony @ ATUS
1,290 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 58
Past 30 Days: 195
All Time: 1,847
