ASUS ZenWatch Motherboard Replacement
  1. ASUS ZenWatch Motherboard Replacement, Watch Strap Removal: step 1, image 1 of 2 ASUS ZenWatch Motherboard Replacement, Watch Strap Removal: step 1, image 2 of 2
    • On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
  2. ASUS ZenWatch Motherboard Replacement, Battery: step 2, image 1 of 3 ASUS ZenWatch Motherboard Replacement, Battery: step 2, image 2 of 3 ASUS ZenWatch Motherboard Replacement, Battery: step 2, image 3 of 3
    • Use the T5 Torx driver to remove the four screws on the case.
    • Use the magnetic pad to keep all your parts easily contained!
    • The case will pry easily off with just gentle hand pressure
  3. ASUS ZenWatch Motherboard Replacement: step 3, image 1 of 2 ASUS ZenWatch Motherboard Replacement: step 3, image 2 of 2
    • Using the tweezers, gently remove the fabric protecting the battery connection.
    • Take care when removing the fabric. Too much force may damage the contact with the metal tweezers.
    • Use the heavy duty spudger to gently push the contact towards the top of the case.
  4. ASUS ZenWatch Motherboard Replacement: step 4, image 1 of 3 ASUS ZenWatch Motherboard Replacement: step 4, image 2 of 3 ASUS ZenWatch Motherboard Replacement: step 4, image 3 of 3
    • Gently pry the battery up with the plastic pry tools
  5. ASUS ZenWatch Motherboard Replacement, Motherboard: step 5, image 1 of 3 ASUS ZenWatch Motherboard Replacement, Motherboard: step 5, image 2 of 3 ASUS ZenWatch Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • With the metal tweezers gently remove the fabric covering the connection on bottom right
    • Using the heavy duty plastic spudger pry up on the connection ribbon.
    • There are two connection ports on the single ribbon. Do not use too much force as you may tear ribbon!
  6. ASUS ZenWatch Motherboard Replacement: step 6, image 1 of 3 ASUS ZenWatch Motherboard Replacement: step 6, image 2 of 3 ASUS ZenWatch Motherboard Replacement: step 6, image 3 of 3
    • The protective plate is now ready to be safely removed.
    • With the heavy duty spudger pry up on the metal plate, in a counter-clockwise pattern
    • There are tiny notches on plate making it simple to pull up on each side.
    • A small strip of adhesive is on back of plate as well.
    • Remove loosened plate and set aside.
  7. ASUS ZenWatch Motherboard Replacement: step 7, image 1 of 3 ASUS ZenWatch Motherboard Replacement: step 7, image 2 of 3 ASUS ZenWatch Motherboard Replacement: step 7, image 3 of 3
    • With the 000 Philips screwdriver remove the screw and plastic retainer clips
  8. ASUS ZenWatch Motherboard Replacement: step 8, image 1 of 2 ASUS ZenWatch Motherboard Replacement: step 8, image 2 of 2
    • With heavy duty spudger lift up on final connection ribbon located on left corner.
  9. ASUS ZenWatch Motherboard Replacement: step 9, image 1 of 2 ASUS ZenWatch Motherboard Replacement: step 9, image 2 of 2
    • With all the connections disconnected the motherboard can be gently pried up and out of the watch case.
Wayne McClure
961 Reputation
5 Guides authored
USF Tampa, Team 1-3, Sullivan Spring 2016 Member of USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Members
7 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 1,592
