Dell Latitude E6400 CPU Replacement
    1. Dell Latitude E6400 CPU Replacement, Battery Removal: step 1, image 1 of 3 Dell Latitude E6400 CPU Replacement, Battery Removal: step 1, image 2 of 3 Dell Latitude E6400 CPU Replacement, Battery Removal: step 1, image 3 of 3
      • Disconnect AC power adaptor
      • Push battery release tabs inwards.
      • Slide the battery out of the computer.
      Ask FixBot
    2. Dell Latitude E6400 CPU Replacement, Bottom Lid: step 2, image 1 of 2 Dell Latitude E6400 CPU Replacement, Bottom Lid: step 2, image 2 of 2
      • Remove the one 7.5 mm Phillips screw securing the bottom case.
      • Pull the bottom lid towards yourself to remove it.
      Ask FixBot
    3. Dell Latitude E6400 CPU Replacement, Fan: step 3, image 1 of 3 Dell Latitude E6400 CPU Replacement, Fan: step 3, image 2 of 3 Dell Latitude E6400 CPU Replacement, Fan: step 3, image 3 of 3
      • Remove the two 4.8mm Phillips screws securing the fan.
      • Disconnect the fan by pulling power cable straight up.
      • Lift the fan with your finger and slide it out towards the inside of the laptop.
      Ask FixBot
    4. Dell Latitude E6400 CPU Replacement, Heat Sink: step 4, image 1 of 2 Dell Latitude E6400 CPU Replacement, Heat Sink: step 4, image 2 of 2
      • Remove the four Phillips screws securing the heat sink.
      • Using your finger gently lift and remove heat sink .
      Ask FixBot
    5. Dell Latitude E6400 CPU Replacement: step 5, image 1 of 1
      • Gently rotate left the locking screw to release CPU from its socket.
      • Lift the CPU straight up of it's socket.
      Ask FixBot
D. K. Labudek
685 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 78
All Time: 930
