Community-Contributed Guide
Unscrew one of the grilles and saw it apart. On the photo you can see how mine looks in the end. I had decided to make the gate 6 bars wide.
Organize a bolt about 6 cm long. I took a screw and sawed off the thick end.
Drill a hole in each of the two upper horizontal edges/boards. For me it is 3 cm each. Drill as centrally and horizontally as possible, or minimally upwards.
Insert the bolt and push the two grille parts together.
Done. Maybe you could think of something else so that the gate stays up when you press against it. However, you can turn the gate 270° and put it on top to get a permanent opening.
Special thanks to these translators:
100%
Gegu is helping us fix the world! Want to contribute?
Start translating ›
