ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement
  1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
    • Flip the laptop onto its backside.
    • Use a Phillips #00 screwdriver to remove the nine 1.2 mm Phillips #00 screws screws attached to the laptop backing.
  2. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: step 2, image 1 of 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: step 2, image 2 of 2
    • Remove the laptop backing with a prying tool. Use the prying tool between the keyboard and bottom grooves.
    • Start prying from the center of the laptop and work your way around the edges of the laptop to remove the keyboard panel.
    • It is recommended to use a plastic prying tool versus a metal prying tool as it could scratch your laptop.
  3. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: step 3, image 1 of 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: step 3, image 2 of 2
    • Separate the laptop keyboard from the laptop backing.
    • Carefully remove the keyboard connector from the motherboard.
  4. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: step 4, image 1 of 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: step 4, image 2 of 2
    • Remove the two 3 mm screws attached to the laptop's hard drive metal cage using the Phillips #00 screwdriver.
    • Once the screws have been removed, gently disconnect the hard drive by pulling the hard drive away from the integrated SATA port.
  5. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: step 5, image 1 of 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: step 5, image 2 of 2
    • Remove the four 3 mm screws attached to hard drive metal cage using the Phillips #00 screwdriver.
    • Remove the hard drive from the bracket.
David Nguyen
202 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 53
All Time: 1,740
