Introduction
Use this prerequisite instead of the CPU Fan / Heatsink guide when removing the motherboard is required to access other parts. In those cases, it is not necessary to remove the heatsink and fan, as only one screw is fastened to the case rather than directly to the motherboard.
Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
Using a spudger, lift up the plug connecting the battery to the motherboard.
Remove the screw securing the fan to the palm rest. All other fan and heatsink screws can remain in place.
