ASUS Vivo AiO V241IC HDD and RAM Replacement
  1. ASUS Vivo AiO V241IC HDD and RAM Replacement, Remove 4 screws: step 1, image 1 of 1
    • Power off your device
    • Place it horizontaly on the stable ground
    • Remove 4 screws at the bottom of the display
    • Take grey panel from the sides and pull it up
    • Be careful to pulling up - there are two connectors, which goes from display to motherboard. You can safelly lift display for 5-7 cm (like on the photo)
  2. ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: step 2, image 1 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: step 2, image 2 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: step 2, image 3 of 3
    • After disconnecting two connectors from the motherboard you can lift display up
    • There is an also connector to display from motherboard and do not hurry to lift up display
    • There is no metal cover from the motherboard on this photo
  3. ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: step 3, image 1 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: step 3, image 2 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: step 3, image 3 of 3
    • Now you can see motherboard, covered up by metal cover
    • HDD - on the left side. Remove screws and pull HDD-case
  4. ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: step 4, image 1 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: step 4, image 2 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: step 4, image 3 of 3
    • Remove screws from the metal cover and pull up - you can see the motherboard
    • RAM - 2 Slots, DDR4 2400 Mhz
  5. ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard front side overview: step 5, image 1 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard front side overview: step 5, image 2 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard front side overview: step 5, image 3 of 3
    • Here you can find more details of the V241ICR-R rev 2.0 mainboard.
    • This refers to V241ICGK-BA111T model of the PC
  6. ASUS Vivo AiO V241IC HDD and RAM Replacement, Accessing SSD slot: step 6, image 1 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Accessing SSD slot: step 6, image 2 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Accessing SSD slot: step 6, image 3 of 3
    • Remove all marked screws to get to the other side of the mainboard.
    • Dont forget the central one, the Fan and all the cables before lifting the MB. It goes up easy but may be some sticky glue below.
  7. ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard back side overview: step 7, image 1 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard back side overview: step 7, image 2 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard back side overview: step 7, image 3 of 3
    • Here you can find NGFF M.2 (key M) slot for 2280 size SSD.
    • Install any AHCI (mSATA) SSD. Modules with both keys B+M are OK. Note that NVME and other PCI-E/USB modules are NOT supported.
    • You may need an extra srew to fix your new SSD in the slot.
    • Reasseble the system in reverse order
Konstantin Epikhin
471 Reputation
1 Guide authored
Past 24 Hours: 4
Past 7 Days: 34
Past 30 Days: 186
All Time: 22,856
