Shop the Holiday Gift Guide
ASUS UX50V-RX05 Case Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
3
All Time:
231
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. ASUS UX50V-RX05 Case Removal, Keyboard: step 1, image 1 of 3 ASUS UX50V-RX05 Case Removal, Keyboard: step 1, image 2 of 3 ASUS UX50V-RX05 Case Removal, Keyboard: step 1, image 3 of 3
      • Make sure the device is powered off and the battery is removed before beginning.
      • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
      Ask FixBot
    2. ASUS UX50V-RX05 Case Removal: step 2, image 1 of 2 ASUS UX50V-RX05 Case Removal: step 2, image 2 of 2
      • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
      • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
      • Remove the cable after pushing out the two black clips.
      Ask FixBot
    3. ASUS UX50V-RX05 Case Removal: step 3, image 1 of 2 ASUS UX50V-RX05 Case Removal: step 3, image 2 of 2
      • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
      • Remove the cable after pushing out both black clips.
      • Remove the keyboard.
      Ask FixBot
    1. ASUS UX50V-RX05 Case Removal, Case Removal: step 4, image 1 of 3 ASUS UX50V-RX05 Case Removal, Case Removal: step 4, image 2 of 3 ASUS UX50V-RX05 Case Removal, Case Removal: step 4, image 3 of 3
      • Remove the thirteen 5 mm J0 screws from the back of the laptop.
      • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
      Ask FixBot
    2. ASUS UX50V-RX05 Case Removal: step 5, image 1 of 2 ASUS UX50V-RX05 Case Removal: step 5, image 2 of 2
      • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
      Ask FixBot
    3. ASUS UX50V-RX05 Case Removal: step 6, image 1 of 3 ASUS UX50V-RX05 Case Removal: step 6, image 2 of 3 ASUS UX50V-RX05 Case Removal: step 6, image 3 of 3
      • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
      • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
      Ask FixBot
    4. ASUS UX50V-RX05 Case Removal: step 7, image 1 of 1
      • Carefully lift and remove the plastic cover to avoid damaging anything.
      Ask FixBot
Author
with
James
663 Reputation
6 Guides authored
USF Tampa, Team 20-2, Remmell Spring 2017 Member of USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 231
