Shop the Holiday Gift Guide
ASUS Q302L Back Case Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
2
Past 30 Days:
8
All Time:
206
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite Only
Tools
    1. ASUS Q302L Back Case Replacement, Back Case: step 1, image 1 of 1
      • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
      • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
      Ask FixBot
    2. ASUS Q302L Back Case Replacement: step 2, image 1 of 3 ASUS Q302L Back Case Replacement: step 2, image 2 of 3 ASUS Q302L Back Case Replacement: step 2, image 3 of 3
      • Wedge a plastic opening tool under the rear case near the hinge.
      • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
      Ask FixBot
    3. ASUS Q302L Back Case Replacement: step 3, image 1 of 1
      • Once the cover is free from all the clips, remove the cover from the laptop.
      Ask FixBot
Author
with
Kerolus Gerges
231 Reputation
2 Guides authored
USF Tampa, Team S13-G4, Cagle Spring 2017 Member of USF Tampa, Team S13-G4, Cagle Spring 2017
USFT-CAGLE-S17S13G4
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 8
All Time: 206
