Introduction
This guide will show how to replace the motherboard of the ASUS Portable AiO PT2001.
Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
Disconnect the three cables connecting the back panel ports to the motherboard.
Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
Gently wiggle the third connector out of its socket.
Peel off the tape attaching the metal enclosure to the heat sink.
Lift the metal enclosure off of the motherboard.
Pull the jaws of the white plastic frame apart. This will pop the front of the RAM up.
Gently lift the front edge of the RAM.
Pull the RAM out and up.
The wireless card is on the corner of the motherboard next to the speaker. Remove the black tape to reveal the wireless card.
Remove the 3.5 mm Phillips #1 screw from the wireless card.
Remove the connectors by pulling straight up on their ends.
Remove the tape attached to the heat sink and the metal enclosure.
Lift the metal enclosure off.
Remove the four 3.0 mm Phillips #1 screws attaching the heat sink to the motherboard.
Remove the three 4.0 mm Phillips #1 screws connecting the fan to the device.
Flip up the locking mechanism and disconnect the three cables using a nylon spudger.
Disconnect two more cables by pulling back on the cable using a nylon spudger.
Disconnect the battery cable by pulling up on the black connector.
Use a Phillips #1 screwdriver to remove the four-5mm screws that hold the hard drive enclosure to the PC.
Pull the hard drive away from the motherboard and set it aside.
Use a Phillips #1 screwdriver to remove the nine-3.5mm screws located at the sides of the motherboard.
