John Frieda JFHA5R Reset and Test Buttons Replacement
    1. John Frieda JFHA5R Reset and Test Buttons Replacement, Reset and Test Buttons: step 1, image 1 of 1
      • Make sure the Salon Shape brush is unplugged, and do not use metals once you have pried open the power plug.
      • Unscrew the two screws using a 3.0 mm bit triangle head on the back of the power plug.
      Ask FixBot
    2. John Frieda JFHA5R Reset and Test Buttons Replacement: step 2, image 1 of 1
      • Use the spudger along either side to open up the power plug.
      • As the power plug is opened, the caution sticker on top of the plug will rip.
      Ask FixBot
    3. John Frieda JFHA5R Reset and Test Buttons Replacement: step 3, image 1 of 1
      • Slide slightly up to remove the back cover of the power plug.
      Ask FixBot
    4. John Frieda JFHA5R Reset and Test Buttons Replacement: step 4, image 1 of 1
      • Remove the red reset button by pulling it to the right.
      Ask FixBot
    5. John Frieda JFHA5R Reset and Test Buttons Replacement: step 5, image 1 of 1
      • Pull slightly left then up to remove the yellow test button.
      Ask FixBot
Lindsey Farley
116 Reputation
1 Guide authored
IUPUI, Team S5-G1, Baechle Fall 2017 Member of IUPUI, Team S5-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G1
3 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 34
All Time: 991
