ASUS Laptop Battery, SSD, and RAM Removal
    1. ASUS Laptop Battery, SSD, and RAM Removal, Unscrew the Back Cover: step 1, image 1 of 2 ASUS Laptop Battery, SSD, and RAM Removal, Unscrew the Back Cover: step 1, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the 11 screws securing the back panel.
      • Don't forget the screw hidden inside the SD card slot — this one is easy to miss.
      • Screw lengths may vary. Keep track of their original positions using a magnetic project mat or labeled containers.
      Ask FixBot
    2. ASUS Laptop Battery, SSD, and RAM Removal, Pry Open the Back Cover: step 2, image 1 of 2 ASUS Laptop Battery, SSD, and RAM Removal, Pry Open the Back Cover: step 2, image 2 of 2
      iFixit Opening Tool
      $1.99
      Buy
      • Use a plastic opening tool to gently separate the back cover from the chassis.
      • Start on one side (left or right) and carefully work your way around the entire perimeter.
      • Take your time to avoid damaging clips or scratching the surface.
      • If the cover feels stuck, double-check that all screws are fully removed — especially the one in the SD slot.
      Ask FixBot
    3. ASUS Laptop Battery, SSD, and RAM Removal, Remove the Battery: step 3, image 1 of 1
      • Locate the two screws securing the battery.
      • These screws won’t come out completely — just loosen them until they turn freely.
      • Lift the small black tab upward to disconnect the battery from the motherboard.
      • Gently remove the battery and set it aside.
      Ask FixBot
    4. ASUS Laptop Battery, SSD, and RAM Removal, Remove the SSD: step 4, image 1 of 2 ASUS Laptop Battery, SSD, and RAM Removal, Remove the SSD: step 4, image 2 of 2
      • Remove the single screw holding the SSD in place.
      • It's very small — don’t lose it.
      • Pull the SSD out in the direction it’s facing (usually upward at a slight angle).
      • Avoid bending or twisting the drive during removal.
      Ask FixBot
    5. ASUS Laptop Battery, SSD, and RAM Removal, Remove the RAM Module: step 5, image 1 of 1
      • Locate the metal retaining tabs on each side of the memory stick.
      • Pull the left tab to the left and the right tab to the right.
      • The RAM will pop up at an angle.
      • Gently slide it out of the slot.
      • To reinstall or replace it, insert the module at an angle, then press it down until it clicks into place.
      Ask FixBot
      • To reassemble your device, follow the steps in reverse order, carefully reconnecting each component. Pay close attention to:
      • Proper alignment of connectors (especially the battery tab and SSD)
      • Returning each screw to its original position — screw lengths may vary
      • Gently snapping the back cover into place before tightening screws
      • Use your magnetic mat or photos from disassembly to double-check part placement before powering on the device.
      Ask FixBot
If your laptop doesn’t power on after reassembly or shows unusual behavior, don’t worry — it may just be a loose connector or unseated component.
ThorTheMainGod
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 56
Past 30 Days: 298
All Time: 2,661
