ASUS D550MA-DS01 Keyboard Module Replacement
  1. ASUS D550MA-DS01 Keyboard Module Replacement, Keyboard Module: step 1, image 1 of 2 ASUS D550MA-DS01 Keyboard Module Replacement, Keyboard Module: step 1, image 2 of 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use the Philips #1 Screwdriver to remove the 9 screws that hold the keyboard cover in place.
  2. ASUS D550MA-DS01 Keyboard Module Replacement: step 2, image 1 of 1
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
  3. ASUS D550MA-DS01 Keyboard Module Replacement: step 3, image 1 of 2 ASUS D550MA-DS01 Keyboard Module Replacement: step 3, image 2 of 2
    • Make sure that the entire cover has been released from the plastic pins.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove.
    • Note the locations of the 3 white and blue data cables connecting to the keyboard to the computer's main board.
  4. ASUS D550MA-DS01 Keyboard Module Replacement: step 4, image 1 of 1
    • Remove each data cable from the motherboard by using your finger or the black spudger to lift the black latch.
    • The cable will slide out of its place.
  5. ASUS D550MA-DS01 Keyboard Module Replacement: step 5, image 1 of 1
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
redacted
543 Reputation
3 Guides authored
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 35
All Time: 1,898
