ASUS Chromebox 4 SSD / Memory Replacement
    1. ASUS Chromebox 4 SSD / Memory Replacement, Create a recovery USB: step 1, image 1 of 1
      • Especially if you are replacing the SSD, you will need the recovery USB to reinstall ChromeOS on the new SSD, or the Chromebox won't boot.
      • Follow the instructions from Google's website to create a recovery USB stick: https://support.google.com/chromeosflex/...
      • You will need an USB stick with at least 8GB of capacity (the contents of the stick will be overwritten!) and a system running the Chrome browser - so it's easiest to do it on the Chromebox before taking it apart for an upgrade.
      Ask FixBot
    2. ASUS Chromebox 4 SSD / Memory Replacement, Remove the feet: step 2, image 1 of 1
      • Gently remove the feet of the device. They are glued on using soft glue and should come off easily.
      Ask FixBot
    3. ASUS Chromebox 4 SSD / Memory Replacement, Remove the screws: step 3, image 1 of 1
      • Remove the 4 screws you uncovered by removing the feet.
      Ask FixBot
    4. ASUS Chromebox 4 SSD / Memory Replacement, Remove the top: step 4, image 1 of 1
      • Gently remove the top. Take care of the connector cable that links the power input socket with the motherboard.
      Ask FixBot
    5. ASUS Chromebox 4 SSD / Memory Replacement, Update RAM/SSD: step 5, image 1 of 1
      • You can update the SSD by removing two screws (the WiFi card needs to be removed first).
      • To test the machine without putting it back together, you can use an USB-C laptop charger to power it temporarily.
      • If you replaced the SSD, you will have to use the recovery USB created on the first step to restore the operating system.
      Ask FixBot
3 other people completed this guide.
Wooing Snowdrift
450 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 46
Past 30 Days: 205
All Time: 2,483
