Introduction
This repair guide will walk you through the steps to removing and replacing the internal drive component of your APS Tech 101629 CD-Drive. First the external casing will need to be removed.
Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
Rotate so the back of the device is facing you.
Gently pry the back casing away.
When the back casing is removed, the fan will become loose.
Flip so device is upside down.
Remove 4 screws with Phillips #1 screw driver.
Slide the internal drive component away from the back of the device.
Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
Audio Connection
SCSI ID
Terminate On
SCSI Connection
DC Input (power)
