APS Tech 101629 External Casing Replacement
  1. APS Tech 101629 External Casing Replacement, External Casing: step 1, image 1 of 3 APS Tech 101629 External Casing Replacement, External Casing: step 1, image 2 of 3 APS Tech 101629 External Casing Replacement, External Casing: step 1, image 3 of 3
    • Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 External Casing Replacement: step 2, image 1 of 2 APS Tech 101629 External Casing Replacement: step 2, image 2 of 2
    • Unscrew the four screws previously covered by the feet.
  3. APS Tech 101629 External Casing Replacement: step 3, image 1 of 2 APS Tech 101629 External Casing Replacement: step 3, image 2 of 2
    • Flip the device right side up, then gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 External Casing Replacement: step 4, image 1 of 1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 External Casing Replacement: step 5, image 1 of 2 APS Tech 101629 External Casing Replacement: step 5, image 2 of 2
    • Rotate so back of device is facing you, then gently pry the back casing away.
    • When back casing is removed, the fan will become loose.
Patrick Meyer
83 Reputation
3 Guides authored
Cal Poly, Team 24-60, Amido Spring 2011 Member of Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 713
