Introduction
The keypad is an extremely important component of the ACN Iris WG4K. It is important because it is the only way you can interact with your device. It recieves all of its commands through the soft keys. If the keypad no longer works, lags, or is damaged, look at this guide for instructions on how to replace it.
Press upwards with your index finger on the 4P4C connector as shown in the image.
Pull the connector gently out of its socket.
Flip the main body of the video phone so that the bottom is facing up.
Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
Use the Phillips #0 Screwdriver to remove the four Phillips head screws 6 mm highlighted by the red circles.
