B. Front Panel
  1. B. Front Panel, Front Panel Assembly: step 1, image 1 of 2 B. Front Panel, Front Panel Assembly: step 1, image 2 of 2
    • Start by placing the NeoPixel rings into the circles. Make sure the pins are at the top center.
    • Thread the Inner Fan part into the circle.
    • Thread the tip into the Inner Fan.
  2. B. Front Panel, Front Panel Assembly: step 2, image 1 of 2 B. Front Panel, Front Panel Assembly: step 2, image 2 of 2
    • Screw the assembled Circle parts into the Front Face using 12x M3x8 countersunk screws
  3. B. Front Panel, Front Panel Assembly: step 3, image 1 of 3 B. Front Panel, Front Panel Assembly: step 3, image 2 of 3 B. Front Panel, Front Panel Assembly: step 3, image 3 of 3
    • Glue the letters into the Middle Name Plate
    • Slide in the Middle Name Plate, Left and Right Nets into the Assembled Front Panel
    • Using 2x M3x8 button head screws secure the Middle Name Plate to the Assembled Front Panel.
  4. B. Front Panel, Front Panel Assembly: step 4, image 1 of 1
    • Slide in the Left and Right Grill into the Front Panel Assembly
  5. B. Front Panel, Front Panel Mounting: step 5, image 1 of 2 B. Front Panel, Front Panel Mounting: step 5, image 2 of 2
    • The Front Panel mounts to the Frame with 4x M3x8 socket head/button head screws with 4x M3 T-Nuts and 2x M5x10 button head screws with 2 M5 T-Nuts
    • The Left and Right Lower Front Grill mount to the frame of the printer with 4x M3x8 button head screws with 4x M3 T-Nuts
  6. B. Front Panel, LCD: step 6, image 1 of 3 B. Front Panel, LCD: step 6, image 2 of 3 B. Front Panel, LCD: step 6, image 3 of 3
    • Mount the backplate to the arm with 2x M3x8 button head screws.
    • Mount the ball to the arm with 1x M3x8 socket head screw.
    • I also used a drop of superglue.
    • Insert the PanelDue into the backplate lining up the screw holes. Screw the backplate to the front plate with 4x M3x10 button head screws.
    • Mount the full assembly to the front frame re-enforcement with 2x M5x10 button head screws and 2x M5 T-nuts
  7. B. Front Panel, Results: step 7, image 1 of 2 B. Front Panel, Results: step 7, image 2 of 2
    • Looks pretty cool huh?
Finish Line
4 other people completed this guide.
David Husolo
9,232 Reputation
33 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 23
All Time: 1,492
