8BitDo Ultimate Wireless Joystick Cover Replacement
    1. 8BitDo Ultimate Wireless Joystick Cover Replacement, Case: step 1, image 1 of 2 8BitDo Ultimate Wireless Joystick Cover Replacement, Case: step 1, image 2 of 2
      • Insert an opening pick into the seam between the left controller grip and main controller body.
      • Pry the grip off.
      • Repeat for the right grip.
      Ask FixBot
    2. 8BitDo Ultimate Wireless Joystick Cover Replacement: step 2, image 1 of 2 8BitDo Ultimate Wireless Joystick Cover Replacement: step 2, image 2 of 2
      • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
      Ask FixBot
    3. 8BitDo Ultimate Wireless Joystick Cover Replacement: step 3, image 1 of 3 8BitDo Ultimate Wireless Joystick Cover Replacement: step 3, image 2 of 3 8BitDo Ultimate Wireless Joystick Cover Replacement: step 3, image 3 of 3
      • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
      • Set the halves next to each other with care not to strain the connected ribbon cables.
      Ask FixBot
    4. 8BitDo Ultimate Wireless Joystick Cover Replacement: step 4, image 1 of 3 8BitDo Ultimate Wireless Joystick Cover Replacement: step 4, image 2 of 3 8BitDo Ultimate Wireless Joystick Cover Replacement: step 4, image 3 of 3
      • The ribbon cable is secured with a locking tab connector.
      • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
      Ask FixBot
    1. 8BitDo Ultimate Wireless Joystick Cover Replacement, Joystick Covers: step 5, image 1 of 1
      • Grip each joystick cap firmly and pull straight up to remove them.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alexander Garcia
473 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 53
Past 30 Days: 205
All Time: 461
