Introduction
You can access the joystick with this guide if you need to replace it. You may need to change the joystick if you're experiencing stick-drift issues or unresponsiveness. For this guide, you will need a plastic opening tool, Phillips #0 screwdriver, TR6 Torx Security screwdriver, and ESD-safe blunt nose tweezers (optional).
This repair process is not too difficult, but be careful to not damage anything when you take off the top panel. Ensure the controller is not plugged into a power source.
Orient the controller such that the back of the controller is facing you.
Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
