Shop the Holiday Gift Guide
8BitDo SN30 Pro+ Controller Rumble Motors Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
95
All Time:
1,417
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide is used for the replacement of the Rumble Motors on your 8BitDo SN30 Pro+ controller.
This guide requires desoldering and soldering the motor wires.
Tools
    1. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: step 1, image 1 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: step 1, image 2 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: step 1, image 3 of 3
      • Place the controller face down.
      • Remove the battery cover.
      • Remove rechargeable battery or AA batteries.
      Ask FixBot
    2. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Trigger Buttons: step 2, image 1 of 2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Trigger Buttons: step 2, image 2 of 2
      • Remove L2 and R2 trigger buttons by pushing them away from the grips.
      Ask FixBot
    3. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: step 3, image 1 of 2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use Tweezers to uncover two screws under the label in the battery compartment.
      • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
      Ask FixBot
    4. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: step 4, image 1 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: step 4, image 2 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: step 4, image 3 of 3
      • At the end of each grip, pry apart the covers.
      • Use fingernail or opening pick to undo the two top clips.
      • One clip next to L button.
      • One clip next to R button
      • Undo the final clip between the joysticks.
      Ask FixBot
    5. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Covers: step 5, image 1 of 1
      • Carefully move the rear cover away and from the front cover. Place it to the left.
      • Do not completely separate. The two halves are still attached via a white ribbon cable.
      Ask FixBot
    1. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: step 6, image 1 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: step 6, image 2 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: step 6, image 3 of 3
      • Unlock the ribbon cable by push open the black plastic tab.
      • The tab will slide about 1.5mm
      • Pull the ribbon cable out of the connector in the direction of the cable.
      Ask FixBot
    2. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Caps: step 7, image 1 of 2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Caps: step 7, image 2 of 2
      • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
      Ask FixBot
    3. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: step 8, image 1 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: step 8, image 2 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: step 8, image 3 of 3
      • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
      • Four around the Right stick
      • Four around the Left stick
      • One next to the Battery connector
      Ask FixBot
    4. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: step 9, image 1 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: step 9, image 2 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: step 9, image 3 of 3
      • Pull the two rumble motors out of their housings.
      • Grab the analog sticks to pull out the circuit board
      Ask FixBot
    1. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: step 10, image 1 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: step 10, image 2 of 3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: step 10, image 3 of 3
      • Flip over the rear board
      • Using a soldering iron to desolder the rumble motor wires.
      • During reassembly, remember to solder the wires back into the same position.
      Ask FixBot
Author
with
Brian W
1,800 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 95
All Time: 1,417
