Up to 20% off select tools
8BitDo SN30 Pro+ Controller Buttons Replacement
Views: 12K
View statistics:
Past 24 Hours:
3
Past 7 Days:
33
Past 30 Days:
206
All Time:
12,485
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 8 - 15 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide is used for the replacement any buttons on your 8BitDo SN30 Pro+ controller. This includes A, B, X, Y, Start, Select, Star, Home, and D-Pad buttons.
This guide is also used for the replacement Conductive Rubber Pads.
    1. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: step 1, image 1 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: step 1, image 2 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: step 1, image 3 of 3
      • Place the controller face down.
      • Remove the battery cover.
      • Remove rechargeable battery or AA batteries.
      Ask FixBot
    2. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Trigger Buttons: step 2, image 1 of 2 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Trigger Buttons: step 2, image 2 of 2
      • Remove L2 and R2 trigger buttons by pushing them away from the grips.
      Ask FixBot
    3. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: step 3, image 1 of 2 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use Tweezers to uncover two screws under the label in the battery compartment.
      • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
      Ask FixBot
    4. 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: step 4, image 1 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: step 4, image 2 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: step 4, image 3 of 3
      • At the end of each grip, pry apart the covers.
      • Use fingernail or opening pick to undo the two top clips.
      • One clip next to L button.
      • One clip next to R button
      • Undo the final clip between the joysticks.
      Ask FixBot
    5. 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Covers: step 5, image 1 of 1
      • Carefully move the rear cover away and from the front cover. Place it to the left.
      • Do not completely separate. The two halves are still attached via a white ribbon cable.
      Ask FixBot
    1. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: step 6, image 1 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: step 6, image 2 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: step 6, image 3 of 3
      • Unlock the ribbon cable by push open the black plastic tab.
      • The tab will slide about 1.5mm
      • Pull the ribbon cable out of the connector in the direction of the cable.
      Ask FixBot
    2. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: step 7, image 1 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: step 7, image 2 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: step 7, image 3 of 3
      • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
      • Six 10.1mm screws
      • One 5.8mm screws
      Ask FixBot
    3. 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: step 8, image 1 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: step 8, image 2 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: step 8, image 3 of 3
      • Slide the R buttons up and off its peg.
      • Slide the L button up and off its peg.
      • Remove the main board by rotating it towards the USB-C port. Then lift it out.
      Ask FixBot
    1. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: step 9, image 1 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: step 9, image 2 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: step 9, image 3 of 3
      Buy
      • Use a pair of tweezers or your fingers to remove the five silicone rubber pads.
      • Three black conductive pads.
      • Two clear pads.
      • During reassembly, make sure AXBY conductive rubber has the cut out on the top.
      Ask FixBot
    2. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: step 10, image 1 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: step 10, image 2 of 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: step 10, image 3 of 3
      • Use a pair of tweezers or your fingers to remove the buttons you wish to replace.
      • The Home button is two parts: the center button and the outer clear ring.
      Ask FixBot
10 other people completed this guide.
Author
with
Brian W
1,800 Reputation
8 Guides authored
4 Guide Comments
Hi, it looks like the buttons have little notches that limit where they can go. I was really hoping to modify it so that my a button is green and my b is red would that work if I file down that little notch?
Will Platt - Reply Share
The buttons are all the same height, so feel free to file down. Those nubs are just part of assemble process.
But do leave the 2 longer stems on each side of the button, they stop it from rotating freely.
Brian W - Reply Share
I just completed this guide, and it is 100% perfection. The photos are useful and clear, and explanations are on point. Many thanks.
Chris Zirker - Reply Share
I especially appreciate mention of screw length as I'm prone to mixing them up. Lovely guide 🫠
Joshua Napier - Reply Share
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 206
All Time: 12,485
