3DR Iris Plus Quadcopter Top Shell Replacement
    1. 3DR Iris Plus Quadcopter Top Shell Replacement, Top Shell: step 1, image 1 of 3 3DR Iris Plus Quadcopter Top Shell Replacement, Top Shell: step 1, image 2 of 3 3DR Iris Plus Quadcopter Top Shell Replacement, Top Shell: step 1, image 3 of 3
      • With the back plate off, remove the three 4mm screws using the Hex 2 mm screwdriver. These secure the top plate to the drone assembly.
      Ask FixBot
    2. 3DR Iris Plus Quadcopter Top Shell Replacement: step 2, image 1 of 2 3DR Iris Plus Quadcopter Top Shell Replacement: step 2, image 2 of 2
      • Rotate the drone 180 degrees (top facing up) and remove the top plate from the drone.
      • Exercise caution as there are wires and components attached to the underside of the top plate!
      Ask FixBot
Duncan Applegarth
316 Reputation
3 Guides authored
Cal Poly, Team S7-G5, Regan Winter 2020 Member of Cal Poly, Team S7-G5, Regan Winter 2020
CPSU-REGAN-W20S7G5
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 52
All Time: 603
