Up to 20% off select tools
3D Mechanism Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
89
All Time:
371
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 hours
Difficulty: Difficult
Community-Contributed Guide
Tools
    1. 3D Mechanism Replacement, 3D Mechanism: step 1, image 1 of 3 3D Mechanism Replacement, 3D Mechanism: step 1, image 2 of 3 3D Mechanism Replacement, 3D Mechanism: step 1, image 3 of 3
      • Remove all 6 screws
      Ask FixBot
    2. 3D Mechanism Replacement: step 2, image 1 of 2 3D Mechanism Replacement: step 2, image 2 of 2
      • Armrests Will need to be removed from chair
      • Remove the large bolts located on the left and right hand side of the chair. These can be removed using a large adjustable wrench.
      Ask FixBot
    3. 3D Mechanism Replacement: step 3, image 1 of 3 3D Mechanism Replacement: step 3, image 2 of 3 3D Mechanism Replacement: step 3, image 3 of 3
      • Remove all 6 screws on frame. 2 up top and 2 on both sides.
      Ask FixBot
    4. 3D Mechanism Replacement: step 4, image 1 of 1
      • this speaker wire at the top left of the frame will need to be disconnected.
      Ask FixBot
    5. 3D Mechanism Replacement: step 5, image 1 of 3 3D Mechanism Replacement: step 5, image 2 of 3 3D Mechanism Replacement: step 5, image 3 of 3
      • Next we need to unzip the front of the chair . do so by unzipping all zippers shown in this order. 1 on at top of chair and one at bottom, then one underneath the leather back-pad.
      • THESE ZIPPERS ARE WEAK AND WILL BREAK EASILY IF FORCED.
      Ask FixBot
    6. 3D Mechanism Replacement: step 6, image 1 of 2 3D Mechanism Replacement: step 6, image 2 of 2
      • Now that the front of chair is open remove this small plastic bracket by removing the 2 screws.
      Ask FixBot
    7. 3D Mechanism Replacement: step 7, image 1 of 3 3D Mechanism Replacement: step 7, image 2 of 3 3D Mechanism Replacement: step 7, image 3 of 3
      • The mechanism has a wire harness that runs down to the main PCB in the chair. Most of our 3D mechs come with a new harness pre-attached and the old harness will need to be disconnected from the quick disconnect .
      • Don't disconnect these if your new mechanism has them pre-attached.
      • This is an extremely vague photo , but the quick disconnect is located in the sheath on the lower left hand side of the chair . DON"T CUT THE SHEATHING JUST THE ZIP TIES . If you cant get this zip tied onto the frame like the factory had it no worries just make sure its secured in the general location with zip ties .
      • WHEN RE RUNNING THIS HARNESS BE SURE YOU ARE TAKING NOTE OF THE ORIGINAL ZIP TIE LOCATIONS .
      Ask FixBot
    8. 3D Mechanism Replacement, Wire harness: step 8, image 1 of 3 3D Mechanism Replacement, Wire harness: step 8, image 2 of 3 3D Mechanism Replacement, Wire harness: step 8, image 3 of 3
      • This is the entire upper harness that connects to the 3D mechanism .
      • Lower harness that connects to main PCB . see last step for location
      • Quick disconnect . located on frame .
      Ask FixBot
    9. 3D Mechanism Replacement, lower harness: step 9, image 1 of 3 3D Mechanism Replacement, lower harness: step 9, image 2 of 3 3D Mechanism Replacement, lower harness: step 9, image 3 of 3
      • IF YOU ARE REPLACING THE ENTIRE HARNESS FOLLOW THIS STEP, IF NOT THEN SKIP.
      • Remove the 3 screws on the lower power box cover to gain access to the lower wire harness
      • unscrew the wire harness clip by removing the 2 screws
      • These marked connectors are the motor wires and these are not all of the wires on this harness. please see last step
      Ask FixBot
    10. 3D Mechanism Replacement: step 10, image 1 of 3 3D Mechanism Replacement: step 10, image 2 of 3 3D Mechanism Replacement: step 10, image 3 of 3
      • Now lift up on chair piece and push forward. the chair piece should now be separated from the frame piece.
      • Next remove all 4 bolts on top bracket.
      Ask FixBot
    11. 3D Mechanism Replacement: step 11, image 1 of 3 3D Mechanism Replacement: step 11, image 2 of 3 3D Mechanism Replacement: step 11, image 3 of 3
      • Now remove the upper limit sensor from the 3 plastic pins and move it aside away from the magnet. DO NOT UNPLUG IT
      • Put the chair into Manual Shiatsu and hit the zone button 2 times , sometimes 1 press. You will know you did it right because the arrows will light up in the middle.
      • Shows if your in shiatsu mode .
      • Once these arrows are glowing you can drive the the mech out the top of chair using the UP arrow.
      • DO NOT DRIVE THE MECH OUT UNTIL THE HARNESS HAS BEEN FREED . SEE STEP 7&8
      Ask FixBot
    12. 3D Mechanism Replacement: step 12, image 1 of 1
      • Alternatively you can pop out this magnet instead of the sensor . either way manual shiatsu mode has to be used .
      • BE SURE THIS MAGNET IS ON THE NEW 3D ASSEMBLY BEFORE PUTTING IT INTO THE CHAIR.
      Ask FixBot
    13. 3D Mechanism Replacement: step 13, image 1 of 1
      • The new mech will not come with the plastic wheels , these will need to be transferred from the old mech to the new one. see photo for location of wheels.
      Ask FixBot
    14. 3D Mechanism Replacement, Tips & Extra Things: step 14, image 1 of 3 3D Mechanism Replacement, Tips & Extra Things: step 14, image 2 of 3 3D Mechanism Replacement, Tips & Extra Things: step 14, image 3 of 3
      • If for some reason you cant get the mechanism into the chair due to the top axle blocking it . Its due to this 3D gear not being set at the correct angle.
      • To fix the angle simply remove this cover by removing the 2 screws and spin the motor belt until angle is correct.
      Ask FixBot
    15. 3D Mechanism Replacement: step 15, image 1 of 1
      • New mechanism should be installed below you will see some quick tips and reminders during reassembly.
      • DO NOT TEST MECHANISM IF TOP TRACK BAR IS NOT INSTALLED . WITHOUT THIS TOP BAR ON THE CHAIR THE MECHANISM WILL HAVE ZERO TRACTION AND COULD DAMAGE THE TRACK . SEE STEP 10
      • Remember to install any sensors you remove and to install them the way they were found . see step 11
      • when installing the backrest cover install the 2 middle screws first this will allow the top and bottom screws to automatically line up . see step 1
      Ask FixBot
Author
with
Nick
2,764 Reputation
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 89
All Time: 371
