32" Hisense LED TV Screen Replacement
  1. 32" Hisense LED TV Screen Replacement, Screen: step 1, image 1 of 2 32" Hisense LED TV Screen Replacement, Screen: step 1, image 2 of 2
    • DO NOT plug the TV into power at any time during this process.
    • To begin, lay the TV screen-down on a smooth surface.
    • Unscrew the screws connecting both support legs to the TV.
  2. 32" Hisense LED TV Screen Replacement: step 2, image 1 of 2 32" Hisense LED TV Screen Replacement: step 2, image 2 of 2
    • To begin removing the back plate, find and remove all 18 screws indicated with the Phillips screwdriver.
    • If the screws are difficult to find, remove any screws on the back plate that have an arrow pointing to them like in the second picture.
    • Once all of the screws are removed, carefully pop off the back plate without damaging any of the connected wires.
  3. 32" Hisense LED TV Screen Replacement: step 3, image 1 of 1
    • Slide the power cord free from its metal framework.
    • After the power cord has been moved, remove the four screws keeping the housing in place. Once finished, remove the housing as well.
  4. 32" Hisense LED TV Screen Replacement: step 4, image 1 of 2 32" Hisense LED TV Screen Replacement: step 4, image 2 of 2
    • Remove the three silver screws connecting the circuit board to the rest of the TV that are circled in the picture using the Phillips screwdriver.
    • Remove the final silver screw, making sure to avoid disconnecting any of the wires that obscure it from view.
  5. 32" Hisense LED TV Screen Replacement: step 5, image 1 of 1
    • Remove all of the 18 screws connecting the front frame to the back of the TV with the Torx screwdriver.
  6. 32" Hisense LED TV Screen Replacement: step 6, image 1 of 1
    • Once the screws are all removed, slide the flat-head screwdriver into the small gap between the front and back plates. Use the screwdriver to pry the plates apart and lift the back plate up.
  7. 32" Hisense LED TV Screen Replacement: step 7, image 1 of 1
    • Completely separate the back from the front and flip the back section over so that the screen is now on top.
  8. 32" Hisense LED TV Screen Replacement: step 8, image 1 of 1
    • Find the cable pictured and detach the plastic film protecting the circuitry to which the cable is attached.
    • DO NOT detach both ends of the plastic. Only detach the end that is easily removed from its adhesive.
  9. 32" Hisense LED TV Screen Replacement: step 9, image 1 of 1
    • After detaching the plastic, detach the wire connecting the screen to the rest of the TV.
    • Next, the circuitry needs to be removed from the TV itself. Lift the screen circuitry free from the adhesive and then lift the screen free from the back section of the TV.
  10. 32" Hisense LED TV Screen Replacement: step 10, image 1 of 2 32" Hisense LED TV Screen Replacement: step 10, image 2 of 2
    • Now that the screen has been removed, take the new screen and attach its circuitry in the same place as the previous screen. After that, connect the cable from the rest of the TV to the screen's port and it should be good to go!
23 other people completed this guide.
Connor French
1,367 Reputation
2 Guides authored
Cal Poly, Team 17-2, Green Fall 2015 Member of Cal Poly, Team 17-2, Green Fall 2015
CPSU-GREEN-F15S17G2
4 Members
8 Guides authored
25 Comments
Where can I buy the replacement panel?
Arinah Arin - Reply
Could you please post the panel code of this tv model (32H3C)? I guess it could be the same my hisense tv need . It could help me to find the right spare part.
Thx
Alexis - Reply
where can i buy Hisene LCD TV Screen pls?
H Te Tea - Reply
where do I buy a replacement screen for 32inch hisence smart tv
Shaik Ahmed Khaleck - Reply
How can I buy the 55inch screen. The straight TV not curve
Solomon - Reply
Past 24 Hours: 5
Past 7 Days: 64
Past 30 Days: 319
All Time: 49,423
