Up to 20% off select tools
3. Extruder
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
50
All Time:
50
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 50 minutes
Difficulty: Moderate
3. Extruder
    1. 3. Extruder, How to insert nuts: step 1, image 1 of 3 3. Extruder, How to insert nuts: step 1, image 2 of 3 3. Extruder, How to insert nuts: step 1, image 3 of 3
      • Inserting Hex Nuts: To assure that hex nuts are properly seated, do the following:
      • Insert a screw through a washer.
      • Insert the screw through the hole on the flat side (not the hex cavity side).
      • Add the hex nut on the screw and tighten the screw.
      • Ensure the hex nut is aligned with the hex cavity while tightening.
      • When the nut is fully seated, you need to remove the screw being careful not to dislodge the nut.
      • Inserting Nyloc Nuts: You can use the same method as hex nuts.
      • Inserting Square Nuts: They tend to fall out if the piece holding them is inverted. After they are inserted, check that they are properly seated by inserting a screw to engage that nut.
      Ask FixBot
    2. 3. Extruder, Extruder parts: step 2, image 1 of 2 3. Extruder, Extruder parts: step 2, image 2 of 2
      • extruder_body
      • extruder_cover
      • extruder_idler
      • pinda_mount
      • hotend_collet_clip
      • filament_sensor_cover
      Ask FixBot
    3. 3. Extruder, X carriage parts: step 3, image 1 of 1
      • x_carriage
      • x_carriage_back
      • cable_guide_back (part A and B)
      Ask FixBot
    4. 3. Extruder, Extruder motor: step 4, image 1 of 3 3. Extruder, Extruder motor: step 4, image 2 of 3 3. Extruder, Extruder motor: step 4, image 3 of 3
      • Locate the extruder motor so the wires face to the left. Rotate the shaft so that the flat is facing up.
      • Mount the Bondtech pulley on the extruder motor shaft with the toothed portion on top with the set screw contacting the flat portion of the shaft.
      • The motor shaft should protrude by approximately 1mm.
      • Secure the set screw to avoid the gear moving. We will fine tune the position later.
      • Verify the motor cables orientation.
      • Secure the extruder motor to the extruder_body using two M3x25 screws.
      Ask FixBot
    5. 3. Extruder, X carriage preparation: step 5, image 1 of 3 3. Extruder, X carriage preparation: step 5, image 2 of 3 3. Extruder, X carriage preparation: step 5, image 3 of 3
      • Press an M3 hex nut into the extruder_body.
      • Insert three M3 hex nuts
      • Insert two M3 nylock hex nuts
      Ask FixBot
    6. 3. Extruder, X carriage assembly: step 6, image 1 of 2 3. Extruder, X carriage assembly: step 6, image 2 of 2
      • Verify that the M3x25mm screws are snug
      • Using an M3x10 screw attach the extruder_body to the x_carriage.
      • Using an M3x40 screw and an M3 washer attach the extruder_body to the x_carriage.
      • Verify that extruder_body and x_carriage are correctly aligned. Adjust if necessary with the M3x10 and M3x40 screws
      Ask FixBot
    7. 3. Extruder, Filament sensor assembly: step 7, image 1 of 2 3. Extruder, Filament sensor assembly: step 7, image 2 of 2
      • In order to avoid electrostatic discharge to the filament sensor, touch something metallic that is linked to the ground, for example pipework or a faucet.
      • Verify that the laser sensor is clean. If not, use a cotton bud (q-tip) with a dab of Isopropyl alcohol.
      • Insert the filament sensor into the extruder_body. Avoid touching any of the components on the PCB.
      • Using an M3x10 screw, secure the filament sensor.
      • Don't over-tighten the filament sensor to avoid damaging the PCB.
      Ask FixBot
    8. 3. Extruder, Filament sensor cover assembly: step 8, image 1 of 2 3. Extruder, Filament sensor cover assembly: step 8, image 2 of 2
      • Insert the small PTFE tube in the extruder_body
      • Use two M3x10 screws and the filament_sensor_cover to close the top of the extruder_body
      Ask FixBot
    9. 3. Extruder, Extruder idler preparation: step 9, image 1 of 2 3. Extruder, Extruder idler preparation: step 9, image 2 of 2
      • Locate the Bondtech drive gear. This is the one that has NO set screw.
      • Lubricate the needle bearings with a dab of lithium based grease
      • Slide two Bondtech needle bearings in the Bondtech drive gear.
      Ask FixBot
    10. 3. Extruder, Extruder idler preparation: step 10, image 1 of 3 3. Extruder, Extruder idler preparation: step 10, image 2 of 3 3. Extruder, Extruder idler preparation: step 10, image 3 of 3
      • Place the idler gear into the extruder_idler. Note the orientation of the teeth.
      • Make sure that both needle bearings are still present in the idler gear.
      • Insert the shaft from the direction as shown in the figure.
      • Insert a square nut in the lateral pocket.
      • Double check the orientation of the gears.
      • Double check that no needle bearings fell out during these steps
      Ask FixBot
    11. 3. Extruder, Extruder idler assembly: step 11, image 1 of 3 3. Extruder, Extruder idler assembly: step 11, image 2 of 3 3. Extruder, Extruder idler assembly: step 11, image 3 of 3
      • Slide a M3 washer on a M3x40 screw.
      • Insert the screw in the top left hole of the x_carriage until it is just protruding from the other side of the extruder_body.
      • Add a M3 nylon washer on the end of the screw.
      • Add the extruder_idler in the opening. and push the screw.
      • Leave a space to insert the second M3 nylon washer.
      • Insert the second M3 nylon washer and push the screw further to secure it.
      • Slightly tighten the screw, ensuring that the extruder_idler can still rotate freely.
      Ask FixBot
    12. 3. Extruder, Hotend assembly: step 12, image 1 of 3 3. Extruder, Hotend assembly: step 12, image 2 of 3 3. Extruder, Hotend assembly: step 12, image 3 of 3
      • Hotend wires are not visible in these images. Use the heatblock to orientate the hotend correctly.
      • Push down the PTFE tube while raising up the collet.
      • Insert the hotend_collet_clip. This locks the PFTE tube in place.
      • Insert the hot end into the extruder_body so that the heater and thermistor wires are properly oriented.
      • Note the position of the heater and thermistor wires.
      Ask FixBot
    13. 3. Extruder, Extruder cover assembly: step 13, image 1 of 3 3. Extruder, Extruder cover assembly: step 13, image 2 of 3 3. Extruder, Extruder cover assembly: step 13, image 3 of 3
      • Insert one M3 square nut
      • Insert one M3 hex nut
      • Insert two M3x40 screw to lock the hotend in place
      • Check that the hotend has not rotated, adjust if necessary.
      Ask FixBot
    14. 3. Extruder, Hotend fan assembly: step 14, image 1 of 3 3. Extruder, Hotend fan assembly: step 14, image 2 of 3 3. Extruder, Hotend fan assembly: step 14, image 3 of 3
      • Carefully route the motor wires as shown in the figure.
      • Make sure the wires sit correctly in the channel.
      • This surface will be touching the extruder_body. Wires are going out from this side.
      • Carefully route the hotend fan wires in the x_carriage.
      • Attach the hotend fan with four M3x14 rounded head screws.
      • Check that no wires are pinched.
      • Check hotend fan orientation.
      Ask FixBot
    15. 3. Extruder, Bondtech gear alignment: step 15, image 1 of 3 3. Extruder, Bondtech gear alignment: step 15, image 2 of 3 3. Extruder, Bondtech gear alignment: step 15, image 3 of 3
      • Open the extruder_idler
      • Insert a piece of 1.75 mm filament through the extruder_body into the PFTE tube.
      • Using the Bondtech set screw, carefully center the filament on the drive teeth.
      • Tighten the set screw. Don't tighten too much as you will damage the thread.
      • Remove the filament.
      • This is a good moment to put a dab of lithium based grease on the gears. Make sure to only put grease on the gears, not the drive teeth!
      Ask FixBot
    16. 3. Extruder, Extruder idler tensioner screw: step 16, image 1 of 2 3. Extruder, Extruder idler tensioner screw: step 16, image 2 of 2
      • Make sure you have totally removed the filament from the extruder_body.
      • Slide an extruder spring on a M3x40 screw.
      • Close the extruder_idler door.
      • Slide the screw with the extruder spring in the extruder_body.
      • Tighten the screw in the extruder_idler until the head is flush with the surface of the body.
      • If you have trouble closing the extruder_idler, try rotating the Bondtech idler gear with your finger.
      Ask FixBot
    17. 3. Extruder: step 17, image 1 of 1
      • Slide a M3 washer on a M3x18 screw. Do the same for another M3x18 screw.
      • Attach the print fan using the screws
      • Be careful not to over tighten in order to avoid damaging the fan.
      Ask FixBot
    18. 3. Extruder, Pinda probe assembly: step 18, image 1 of 3 3. Extruder, Pinda probe assembly: step 18, image 2 of 3 3. Extruder, Pinda probe assembly: step 18, image 3 of 3
      • Place a square nut in the extruder_body for the pinda_mount.
      • Slide an M3x10 screw in the pinda_mount and engage the square nut, but do not tighten.
      • Insert the Pinda in the mount so that the sensor end is 12mm below the bottom of the pinda_mount. Tighten the screw just enough to keep the Pinda from falling out. The optimum Pinda position will be adjusted later.
      • Route the Pinda wires
      • Route the print fan wires
      • Secure the cables with a zip tie. Be sure to leave some slack since the Pinda position will need to be adjusted later.
      • This is an example of how the Pinda and print fan cables should be wired.
      Ask FixBot
    19. 3. Extruder, Print fan shroud assembly: step 19, image 1 of 1
      • There is currently no official print fan shroud for the Bear extruder. I recommend the original R1 shroud from Prusa. Some other good alternatives are the shroud from RH_Dreambox or Robps.
      • Insert the print shroud. If necessary, slightly unscrew the print fan.
      • Use an M3x10 screw to attach the shroud
      Ask FixBot
    20. Ask FixBot
Greg Bear
8,773 Reputation
35 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 50
All Time: 50
