2018 Jeep Compass Key Fob Battery Replacement
    1. 2018 Jeep Compass Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 1
      • Remove the valet key from the top by sliding the button over.
      • You can not open the FOB without removing the valet key.
      Ask FixBot
    2. 2018 Jeep Compass Key Fob Battery Replacement: step 2, image 1 of 1
      • Use an opening tool or flathead screwdriver to separate the top and bottom of the key fob.
      Ask FixBot
    3. 2018 Jeep Compass Key Fob Battery Replacement: step 3, image 1 of 3 2018 Jeep Compass Key Fob Battery Replacement: step 3, image 2 of 3 2018 Jeep Compass Key Fob Battery Replacement: step 3, image 3 of 3
      • Use a spudger or pair of tweezers to pull the battery out.
      • Take care not to puncture the battery.
      • You can grab the battery with you fingers once the tweezers raise it out of the battery clasp.
      Ask FixBot
    4. 2018 Jeep Compass Key Fob Battery Replacement: step 4, image 1 of 1
      • Replace the new battery in the battery holder.
      • Make sure that the battery is inserted correctly with positive(+) and negative(-) terminals corresponding with the symbols on the device, or the key fob will not work.
      Ask FixBot
    5. 2018 Jeep Compass Key Fob Battery Replacement: step 5, image 1 of 1
      • Align the two halves of the fob and press them together with your fingers until they snap into place.
      Ask FixBot
    6. 2018 Jeep Compass Key Fob Battery Replacement: step 6, image 1 of 1
      • Replace the valet key at the top.
      Ask FixBot
  • Make sure that the new battery is clasped in.
  • Snap the sides back together.
  • Insert the valet key back into its slot.
  • Test the key fob on your vehicle to ensure it works perfectly.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 78
Past 30 Days: 313
All Time: 1,286
