2015 Dodge Charger SXT Headlight Replacement
    1. 2015 Dodge Charger SXT Headlight Replacement, Headlight Bulb: step 1, image 1 of 1
      • Before you begin, make sure the car is turned off and placed in park.
      • Pop open your hood.
      • This model of Charger does not require a stand to hold the hood. It will automatically hold on its own.
      Ask FixBot
    2. 2015 Dodge Charger SXT Headlight Replacement: step 2, image 1 of 3 2015 Dodge Charger SXT Headlight Replacement: step 2, image 2 of 3 2015 Dodge Charger SXT Headlight Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the three screws that secure the intake filter cover.
      • Slowly loosen the screws. Loosening them too quickly may result in the screw falling into the engine compartment.
      • Grab the intake cover with both hands and gently lift upwards.
      • Place the cover safely on top of the main engine.
      Ask FixBot
    3. 2015 Dodge Charger SXT Headlight Replacement: step 3, image 1 of 3 2015 Dodge Charger SXT Headlight Replacement: step 3, image 2 of 3 2015 Dodge Charger SXT Headlight Replacement: step 3, image 3 of 3
      • Once the air intake cover is removed, the air filter can be taken out.
      Ask FixBot
    4. 2015 Dodge Charger SXT Headlight Replacement: step 4, image 1 of 3 2015 Dodge Charger SXT Headlight Replacement: step 4, image 2 of 3 2015 Dodge Charger SXT Headlight Replacement: step 4, image 3 of 3
      • Loosen the bolt using a ratchet and an 8mm socket.
      • Lift the air intake compartment up and out of the engine bay.
      Ask FixBot
    5. 2015 Dodge Charger SXT Headlight Replacement: step 5, image 1 of 3 2015 Dodge Charger SXT Headlight Replacement: step 5, image 2 of 3 2015 Dodge Charger SXT Headlight Replacement: step 5, image 3 of 3
      • Once the intake is safely removed, you can access the headlight compartment.
      • Remove the headlight compartment cap by twisting it counterclockwise.
      Ask FixBot
    6. 2015 Dodge Charger SXT Headlight Replacement: step 6, image 1 of 3 2015 Dodge Charger SXT Headlight Replacement: step 6, image 2 of 3 2015 Dodge Charger SXT Headlight Replacement: step 6, image 3 of 3
      • Remove the headlight compartment by twisting it counterclockwise.
      • Now remove the old headlight bulb by lifting the small lever.
      • Use gloves or a rag to keep from touching old oils or burnt marks.
      Ask FixBot
    7. 2015 Dodge Charger SXT Headlight Replacement: step 7, image 1 of 3 2015 Dodge Charger SXT Headlight Replacement: step 7, image 2 of 3 2015 Dodge Charger SXT Headlight Replacement: step 7, image 3 of 3
      • Connect the new headlight bulb and firmly align the bulb to the compartment.
      • Insert it back into the compartment and turn it clockwise to secure it.
      • Double check that the bulb is properly installed and connected. If it is not installed properly, you will have to remove the intake once more.
      • Use gloves or a rag. Do not touch the new headlight bulb with your fingers as it can damage it and lower its performance.
      Ask FixBot
    8. 2015 Dodge Charger SXT Headlight Replacement: step 8, image 1 of 3 2015 Dodge Charger SXT Headlight Replacement: step 8, image 2 of 3 2015 Dodge Charger SXT Headlight Replacement: step 8, image 3 of 3
      • Place the intake compartment back in its original place. Tighten the screw with the 8mm socket used in step 4
      • Place the air filter back in its place. Align it with the intake compartment.
      Ask FixBot
    9. 2015 Dodge Charger SXT Headlight Replacement: step 9, image 1 of 3 2015 Dodge Charger SXT Headlight Replacement: step 9, image 2 of 3 2015 Dodge Charger SXT Headlight Replacement: step 9, image 3 of 3
      • Using both hands align the cover with the three screws holes.
      • Tighten the three screws using the Phillips screwdriver.
      • Double check that the air intake is safely secure and not loose.
      Ask FixBot
    10. 2015 Dodge Charger SXT Headlight Replacement: step 10, image 1 of 2 2015 Dodge Charger SXT Headlight Replacement: step 10, image 2 of 2
      • Power on the vehicle to ensure the headlight bulb is successfully working.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 51
All Time: 4,937
