2013 Infiniti G37 Dual Air Intakes Replacement
  1. 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: step 1, image 1 of 3 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: step 1, image 2 of 3 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: step 1, image 3 of 3
    • Pull the hood latch located inside the car under your remote holder.
    • Outside the car, find the lever under the actual hood, and squeeze and lift the hood.
    • Unscrew the mass airflow filter box from the frame with a Phillips #1 screwdriver.
    Ask FixBot
  2. 2013 Infiniti G37 Dual Air Intakes Replacement: step 2, image 1 of 3 2013 Infiniti G37 Dual Air Intakes Replacement: step 2, image 2 of 3 2013 Infiniti G37 Dual Air Intakes Replacement: step 2, image 3 of 3
    • Loosen the five bolts in the engine cover so you can have more space to access the mass airflow tubes.
    Ask FixBot
  3. 2013 Infiniti G37 Dual Air Intakes Replacement: step 3, image 1 of 3 2013 Infiniti G37 Dual Air Intakes Replacement: step 3, image 2 of 3 2013 Infiniti G37 Dual Air Intakes Replacement: step 3, image 3 of 3
    • Loosen the mass airflow sensor from the airflow tube and safely move it to a safe location out of the way.
    • Use vice grips to remove the clamp.
    Ask FixBot
  4. 2013 Infiniti G37 Dual Air Intakes Replacement: step 4, image 1 of 3 2013 Infiniti G37 Dual Air Intakes Replacement: step 4, image 2 of 3 2013 Infiniti G37 Dual Air Intakes Replacement: step 4, image 3 of 3
    • Loosen the last clamp, located at the head of the airflow tube, and give a firm tug towards you to free the entire piece.
    Ask FixBot
  5. 2013 Infiniti G37 Dual Air Intakes Replacement: step 5, image 1 of 3 2013 Infiniti G37 Dual Air Intakes Replacement: step 5, image 2 of 3 2013 Infiniti G37 Dual Air Intakes Replacement: step 5, image 3 of 3
    • Connect the mass airflow tube and tighten the clamps with a flathead screwdriver.
    Ask FixBot
  6. 2013 Infiniti G37 Dual Air Intakes Replacement: step 6, image 1 of 3 2013 Infiniti G37 Dual Air Intakes Replacement: step 6, image 2 of 3 2013 Infiniti G37 Dual Air Intakes Replacement: step 6, image 3 of 3
    • After all the clamps are tightened, place the mass airflow sensor into the tube and tighten with a Phillips #1 screwdriver.
    Ask FixBot
Finish Line
Cordell Bowens
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 59
All Time: 1,582
