2013 GMC Terrain Headlight Bulb Replacement
  1. 2013 GMC Terrain Headlight Bulb Replacement, Headlight Bulb: step 1, image 1 of 1
    • Identify which headlight is out.
  2. 2013 GMC Terrain Headlight Bulb Replacement: step 2, image 1 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 2, image 2 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 2, image 3 of 3
    • Turn the wheels toward the opposite side of the broken headlight.
    • Go to the Front fender on the side with the broken headlight and find the cover on the fender liner.
  3. 2013 GMC Terrain Headlight Bulb Replacement: step 3, image 1 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 3, image 2 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 3, image 3 of 3
    • Use a T15 Torx screwdriver to remove the screw.
    • Turn the cover counterclockwise to remove it.
  4. 2013 GMC Terrain Headlight Bulb Replacement: step 4, image 1 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 4, image 2 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 4, image 3 of 3
    • Reach into the hole to find the round cap to the bulb.
    • Turn it counterclockwise to expose the socket holding the bulb.
  5. 2013 GMC Terrain Headlight Bulb Replacement: step 5, image 1 of 2 2013 GMC Terrain Headlight Bulb Replacement: step 5, image 2 of 2
    • Twist the socket counterclockwise and pull it out to expose the bulb.
  6. 2013 GMC Terrain Headlight Bulb Replacement: step 6, image 1 of 2 2013 GMC Terrain Headlight Bulb Replacement: step 6, image 2 of 2
    • Unclip the old bulb from the socket.
  7. 2013 GMC Terrain Headlight Bulb Replacement: step 7, image 1 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 7, image 2 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 7, image 3 of 3
    • Grab your new bulb.
    • Make sure not to touch the actual bulb because the oils from your skin can cause it to burn out.
    • Plug it back into the socket and twist it clockwise in the hole.
  8. 2013 GMC Terrain Headlight Bulb Replacement: step 8, image 1 of 1
    • Place the headlight cover back on and turn it clockwise to secure it.
  9. 2013 GMC Terrain Headlight Bulb Replacement: step 9, image 1 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 9, image 2 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 9, image 3 of 3
    • Place the inner fender cover over the hole.
    • Twist the cover clockwise until it's tight
    • Screw in the Torx screw until it is tight.
  10. 2013 GMC Terrain Headlight Bulb Replacement: step 10, image 1 of 1
    • Finally, your headlights should both work.
Now your headlights should work perfectly.
Rafaj27
205 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 99
All Time: 946
