Introduction
This guide demonstrates how to replace a thermostat in a 2017 Dodge Charger. The thermostat is a critical component in your vehicle's cooling system, regulating the flow of coolant to the engine. When it fails, your car may overheat, leading to serious engine damage. This guide is designed for individuals with moderate mechanical skills. By following these instructions, you'll be able to replace the thermostat yourself, saving time and money.
Initially you will need this part of the car which is the replacement thermostat.
Once all the pieces are back on and fit properly, you will begin using the coolant refill this container. Once full you can begin to start the car and let it run for a few minutes and you're done!
Start the engine and let it run with the radiator cap off to allow air bubbles to escape.Top off the coolant as needed.
