Introduction
If your BMW X3 tail lights LEDs do not work at night, use this guide to see how an easy fix can solve the issue!
The LED components use a small circuit board (F25 LED Driver) which controls the lights. If these malfunction, it stops the LEDs from lighting up. Just a swap of these circuit board chips can solve the issue.
This guide requires you to order this circuit board in advance. Be sure to turn the vehicle off before starting the repair.
Open the trunk to get behind the taillight. Pop open the plastic cover from behind the light.
Almost done!
Finish Line
