2010-2017 Suzuki Swift Cabin Air Filter Replacement
  1. 2010-2017 Suzuki Swift Cabin Air Filter Replacement, remove the glovebox: step 1, image 1 of 3 2010-2017 Suzuki Swift Cabin Air Filter Replacement, remove the glovebox: step 1, image 2 of 3 2010-2017 Suzuki Swift Cabin Air Filter Replacement, remove the glovebox: step 1, image 3 of 3
    • The cabin air filter is located behind the glovebox. To access it, the glovebox needs to be removed.
    • After opening, 2 supports on the back of the glovebox prevent the glovebox from falling on the floor.
    • With your hands, push the left support to the right, making sure the rubber band doesn't catch on the frame.
    • If the left support can move freely, pull the glovebox towards you and to the left, to also free the right support.
    • Pull the glovebox towards you to pull the bottom hinges free.
  2. 2010-2017 Suzuki Swift Cabin Air Filter Replacement, replace the filter: step 2, image 1 of 2 2010-2017 Suzuki Swift Cabin Air Filter Replacement, replace the filter: step 2, image 2 of 2
    • The cabin air filter can be accessed by removing the cover from the filter housing.
    • Get your fingers behind the cover latches and pull the cover toward you, removing the cover.
    • Pull the filter out, and prevent dirt from falling out.
    • Put the new filter in, and make sure to follow the design of your filter manufacturer (air is pulled in from the top).
    • Put the cover back.
  3. 2010-2017 Suzuki Swift Cabin Air Filter Replacement, put back the glovebox: step 3, image 1 of 2 2010-2017 Suzuki Swift Cabin Air Filter Replacement, put back the glovebox: step 3, image 2 of 2
    • Put the glovebox hinge parts back into the frame hinge parts.
    • Lift the glovebox and push equally on both sides to force the supports back behind the frame.
Finish Line
5 other people completed this guide.
knipwim
14,768 Reputation
42 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 50
Past 30 Days: 230
All Time: 11,898
