2008-2013 Nissan Rogue Low Beam Headlight Replacement
  1. 2008-2013 Nissan Rogue Low Beam Headlight Replacement, Low Beam Headlight: step 1, image 1 of 3 2008-2013 Nissan Rogue Low Beam Headlight Replacement, Low Beam Headlight: step 1, image 2 of 3 2008-2013 Nissan Rogue Low Beam Headlight Replacement, Low Beam Headlight: step 1, image 3 of 3
    • Park the car in a safe area and turn off the engine.
    • Open the hood of the car by pulling the lever with the car emblem that's located at the bottom left of the driver's side.
    • Once propped open, use the support stand located on the interior of the hood and bring it down, inserting the support stand into the hole located on the frame of the vehicle.
  2. 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 2, image 1 of 2 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 2, image 2 of 2
    • In this case, we will be replacing the low-beam headlight on the driver's side.
    • Put on gloves.
  3. 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 3, image 1 of 3 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 3, image 2 of 3 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 3, image 3 of 3
    • Turn the base of the bulb half a turn, counterclockwise and pull it out.
    • Press the release point of the bulb up to release the bulb from the base. The bulb will slide out, allowing for an easy exchange.
    • Compare the new and the old bulb to confirm that they are identical.
  4. 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 4, image 1 of 2 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 4, image 2 of 2
    • Place the new bulb into the base, pressing down firmly until a click is heard.
  5. 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 5, image 1 of 3 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 5, image 2 of 3 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 5, image 3 of 3
    • Place the bulb back into the outlet the same way it was pulled out.
    • Turn the base half a turn, clockwise, into the outlet to put it back into the headlight.
    • Pull lightly on the base to make sure it is secured.
  6. 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 6, image 1 of 3 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 6, image 2 of 3 2008-2013 Nissan Rogue Low Beam Headlight Replacement: step 6, image 3 of 3
    • With the hood still up, turn your key to the accelerator (or ACC) and turn the lights on to ensure all of the headlights are working.
    • Close the hood slowly, making sure it is secured.
    • Once confirmed the light is working, your car is now safe to use on the road.
Congratulations, you have now learned and completed the low beam headlight replacement!
Angelina Molina
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 149
All Time: 3,466
