Installing 2005-2007 Ford Focus Front Brake Rotors
  1. Installing 2005-2007 Ford Focus Front Brake Rotors, Front Wheel: step 1, image 1 of 1
    • Put the car in park (automatic) or neutral (manual).
    • Apply the parking brake.
    • Place chocks behind the rear wheels.
  2. Installing 2005-2007 Ford Focus Front Brake Rotors: step 2, image 1 of 1
    • Use a 19 mm lug wrench to loosen each lug nut a half turn.
  3. Installing 2005-2007 Ford Focus Front Brake Rotors: step 3, image 1 of 2 Installing 2005-2007 Ford Focus Front Brake Rotors: step 3, image 2 of 2
    • Use a hydraulic jack on the car's frame to jack the car.
    • A small notch shows where to place the jack.
    • It is only necessary to jack the car until the wheel no longer touches the ground.
  4. Installing 2005-2007 Ford Focus Front Brake Rotors: step 4, image 1 of 1
    • Place a jack stand on the frame and remove the jack.
    • Never work on or underneath a car that is only supported by a jack. The car may fall, causing serious injury, or even death.
  5. Installing 2005-2007 Ford Focus Front Brake Rotors: step 5, image 1 of 2 Installing 2005-2007 Ford Focus Front Brake Rotors: step 5, image 2 of 2
    • Use a lug wrench to completely remove the four lug nuts.
    • Remove the wheel.
  6. Installing 2005-2007 Ford Focus Front Brake Rotors, Front Brake Rotors: step 6, image 1 of 2 Installing 2005-2007 Ford Focus Front Brake Rotors, Front Brake Rotors: step 6, image 2 of 2
    • The brake fluid reservoir is located towards the back of the engine compartment.
    • Unscrew the cap and remove it.
    • Be careful when handling brake fluid. Wash hands immediately if they come in contact with it. Do not let the fluid touch any painted parts; it will strip the paint.
  7. Installing 2005-2007 Ford Focus Front Brake Rotors: step 7, image 1 of 1
    • Use a turkey baster to remove 2-3 ounces of brake fluid from the reservoir.
    • Never let the fluid level drop below the minimum mark. This will let air into your lines, which will require bleeding to remove.
    • Properly dispose of old brake fluid. Do not reuse it.
  8. Installing 2005-2007 Ford Focus Front Brake Rotors: step 8, image 1 of 1
    • Use a flat head screwdriver or brake spoon to remove the outer pad retaining clip.
    • The clip has a lot of spring energy. Hold onto it with a pair of pliers when removing it to keep it from flying off and injuring someone.
  9. Installing 2005-2007 Ford Focus Front Brake Rotors: step 9, image 1 of 1
    • Use a flat head screwdriver to remove the black plastic guide bolt dust caps.
  10. Installing 2005-2007 Ford Focus Front Brake Rotors: step 10, image 1 of 1
    • Use a 7 mm Allen wrench to remove the two caliper guide bolts.
  11. Installing 2005-2007 Ford Focus Front Brake Rotors: step 11, image 1 of 2 Installing 2005-2007 Ford Focus Front Brake Rotors: step 11, image 2 of 2
    • Remove the clip that holds the brake line to the strut with a pair of vise grips.
    • Pull the brake line towards you and out of the bracket.
  12. Installing 2005-2007 Ford Focus Front Brake Rotors: step 12, image 1 of 2 Installing 2005-2007 Ford Focus Front Brake Rotors: step 12, image 2 of 2
    • Pull the caliper off of the rotor.
    • Place the caliper on top of a box or bucket so the brake line doesn't stretch or kink.
  13. Installing 2005-2007 Ford Focus Front Brake Rotors: step 13, image 1 of 1
    • Pull the outer brake pad from the mounting bracket.
  14. Installing 2005-2007 Ford Focus Front Brake Rotors: step 14, image 1 of 1
    • Remove the inner brake pad from the caliper.
    • The pad is held in place by three metal clips. It may take some force and wiggling to free the pad.
  15. Installing 2005-2007 Ford Focus Front Brake Rotors: step 15, image 1 of 2 Installing 2005-2007 Ford Focus Front Brake Rotors: step 15, image 2 of 2
    • This step is only necessary if you are replacing the guide bolt bushings.
    • Use a flat head screwdriver to push the bushing through its hole in the caliper.
    • Remove the bushing from the caliper.
  16. Installing 2005-2007 Ford Focus Front Brake Rotors: step 16, image 1 of 2 Installing 2005-2007 Ford Focus Front Brake Rotors: step 16, image 2 of 2
    • Remove the two 15 mm mounting bracket bolts.
    • Lift the mounting bracket off the rotor.
  17. Installing 2005-2007 Ford Focus Front Brake Rotors: step 17, image 1 of 1
    • Remove the brake rotor by pulling it straight off the lugs.
    • If the rotor is to be reused, it is a good idea to take it to a shop to check that it is not out of round and to have it turned.
  18. Installing 2005-2007 Ford Focus Front Brake Rotors: step 18, image 1 of 1
    • Install the new rotor over the wheel lugs.
  19. Installing 2005-2007 Ford Focus Front Brake Rotors: step 19, image 1 of 1
    • Reinstall the mounting bracket.
    • Grease the mounting bracket bolts and install them.
    • Mounting bracket bolts should be tightened to 133 ft-lbs.
  20. Installing 2005-2007 Ford Focus Front Brake Rotors: step 20, image 1 of 1
    • Clean the rotor, caliper, and all other hardware with an aerosol brake cleaner.
    • Never use compressed air to clean brake components. Brakes contain asbestos, and blowing the particles into the air could cause serious respiratory problems if inhaled.
  21. Installing 2005-2007 Ford Focus Front Brake Rotors: step 21, image 1 of 1
    • Coat the steel backing plates of the new brake pads with an anti-squeal coating.
  22. Installing 2005-2007 Ford Focus Front Brake Rotors: step 22, image 1 of 1
    • Place the new outer pad on the mounting bracket.
    • Small particles are a common cause of brake noise. Make sure pad and rotor surfaces are clean of all dirt and debris before installing.
  23. Installing 2005-2007 Ford Focus Front Brake Rotors: step 23, image 1 of 2 Installing 2005-2007 Ford Focus Front Brake Rotors: step 23, image 2 of 2
    • This step is only necessary if the guide bolt bushings were removed.
    • Insert the new bushing from the inside of the caliper.
    • Use a flat head screwdriver to help feed the bushing through its hole.
  24. Installing 2005-2007 Ford Focus Front Brake Rotors: step 24, image 1 of 2 Installing 2005-2007 Ford Focus Front Brake Rotors: step 24, image 2 of 2
    • Compress the caliper piston with a C-clamp.
    • Continually check the fluid level in the brake fluid reservoir to make sure it doesn't exceed the maximum level.
    • Install the new inner pad by pressing it into the caliper and making sure the clips are secure.
  25. Installing 2005-2007 Ford Focus Front Brake Rotors: step 25, image 1 of 1
    • Place the caliper back on the rotor.
  26. Installing 2005-2007 Ford Focus Front Brake Rotors: step 26, image 1 of 2 Installing 2005-2007 Ford Focus Front Brake Rotors: step 26, image 2 of 2
    • Grease the two guide bolts and reinstall them.
    • Guide bolts should be torqued to 21 foot-pounds.
    • Reinstall the guide bolt dust caps.
  27. Installing 2005-2007 Ford Focus Front Brake Rotors: step 27, image 1 of 1
    • Place the brake line back in the bracket on the strut.
    • Secure the brake line with the retaining clip. Use the blunt end of a wrench to knock it completely into place.
  28. Installing 2005-2007 Ford Focus Front Brake Rotors: step 28, image 1 of 1
    • Reinstall the retainer clip by first inserting the ends into the two holes in the caliper, then use pliers to stretch the ends onto the mounting bracket.
    • It is always a good idea to use white lithium grease wherever you have metal-on-metal contact.
  29. Installing 2005-2007 Ford Focus Front Brake Rotors: step 29, image 1 of 1
    • Put the wheel back on the car and hand tighten the lug nuts.
    • Lower the car and completely tighten the lug nuts
    • Lug nuts should torqued to 94 foot-pounds.
  30. Installing 2005-2007 Ford Focus Front Brake Rotors: step 30, image 1 of 2 Installing 2005-2007 Ford Focus Front Brake Rotors: step 30, image 2 of 2
    • Place the cap back on the brake fluid reservoir.
    • Turn the key to the "on" position. Press the brake pedal a few times. It should go to the floor once, and then become firm.
    • Fill the brake fluid reservoir with new fluid, if needed.
David Hodson
150,791 Reputation
127 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 44
All Time: 57,233
